Ricoh mpc2503sp email and folder tabs missing
  • BENDER
    HI EVERYBODY
    Has anybody had this before, installed a machine on a short term rental, a reconditioned Ricoh MPC2503 when trying to set up scan to email in address book management the email and folder tab at the bottom along with a few other tabs are missing.
    Im thinking with it being a remanufactured machine the previous kep op may have removed privilages in address book, but i cant find a way to bring them back.
    I have tried reformatting HD complet + instal stamp and recover the address book
    But I can't find the 2 options below
    I 've got only 3 tabs on scan menu : NAME - AUTH INFO - PROTECTION
    miss : EMAIL - FOLDER
    Any suggestions would be appreciated....thanks you
    • 8144
    Re: Ricoh mpc2503sp email and folder tabs missing
    Check the following:
    SP5985-01 = 1
    SP5985-01 = 1
    SP5895-01 = 1
    You could also initialize the address book & reset the admin password back to default in special SP mode then use:
    SP5846-046
    • BENDER
      SP5985-01 = 1
      SP5985-01 = 1
      SP5895-01 = 1
      SP5846-046
      Hi CONTRIBUTOR,
      OK I HAVE CHECKED YOUR ADVISE BELOW - IT S OK
      I FIND THE SOLUTION FOR MY PRB - I ACTIVED ANY OPTION IN SCANNER MENU AND I FIND ALL OPTION : SANNER + FOLDER
      THANK FOR YOUR HELP
        • 8144
        Originally posted by BENDER
        Hi CONTRIBUTOR,
        THANK FOR YOUR HELP
        You're welcome. If the machine has had an NVram fitted these settings change
