MP C4501 - Add Toner then SC364
  • Stormhammer
    • 150
    [Error Code] MP C4501 - Add Toner then SC364
    I recently replaced the whole black PCDU and checked procon results which were good. I previously replaced the black toner pump when the machine first started acting up with an add toner message. Must have a loose harness or something. Anyone seen this before?
  • bob marley
    • Jan 2012
    • 1339
    Re: MP C4501 - Add Toner then SC364
    sc 364 is TD sensor error ( K )
    Live for yourself and you will live in vain. Live for others, and you will live again
    • davel
      • Oct 2011
      • 1108
      Is there a seal covering toner entry.
        • 37560
        Did you replace both the toner pump and the toner tube? Did you use a new or used pump?
        • Stormhammer
          • 150
          An excellent question. When it comes to this model of machine I always do both brand new. The pumps in these machines seem unreliable after awhile and I think I would be shooting myself by putting a recon K pump in the machine. The low threshold voltage is set properly at it's default of .5 of a volt. I'm wondering if the engine board is no good at this point but you'd think there was other indicators.
          • ss12
            • Jul 2008
            • 289
            May be worth checking the Dev clutch as well
