mpc4504
  • Mark Bbb
    • Jun 2012
    • 1662
    mpc4504
    Hello,
    What is your experience? Is it a good machine without troubles?
  • Zeldaman
    • Mar 2011
    • 946
    • Mark Bbb
      • Jun 2012
      • 1662
      Re: mpc4504
      Zeldaman: I would think it is the same engine?
      • Zeldaman
        • Mar 2011
        • 946
        Re: mpc4504
        Hi there!
        The only difference on the 1. view is the fuser-unit equiped with a decurler-roller.
        Greetings...
        • Lagonda
          • Aug 2008
          • 1649
          Re: mpc4504
          So far, so good.
          Have had a couple fail on installation with SC672, needed to replace controller boards to solve. Also one problem with the ribbon cable between the IPU and BCU board.
          Be careful with the new type of ribbon cable connector, you have to squeeze the lugs to disconnect. One of the techs tried to pry the plastic clip like the old style and ruined the board.
          I rate the '04 range as
          • phileaston98
            • Jul 2021
            • 3
            Does anyone know if we could utilise a controller from a MPC4504sp onto another MPC4504sp, will this just not work, or can we get around this by performing a NVRAM clear ?
            • luca72
              • Oct 2017
              • 1784
              Originally posted by Mark Bbb
              Hello,
              I like it, and it works on average well like the whole series, as Zeldaman said, that whole series is equipped with the anti-curling device, which according to the service manual on the lower models is not effective, and therefore is disabled by sp, let's say it makes a little more complicated to disassemble the fuser, and you have to be careful not to break the various weak plastics that compose it, it happened to me, among other things the assy is very expensive.... of the anti-curl unit I mean
              "I'll be back"
              • TonerMunkeh
                Professional Moron
                • 3865
                If it's the same board going into the same model just swap the NVrams over.
                Hit it.
                  • 37533
                  He started a new thread on the problem. After I asked he posted that the problem is SC 672-11. https://www.copytechnet.com/forum/te...4sp-controller
