Ricoh colour proc 651 line problem
  • pythonas
    • Dec 2015
    • 14
    Hi to everyone,i have a problem with a ricoh pro c651 copier and i want some help please..i have a horizontal white line on my colour copies(at the same exactly place) but not on the black and whites.Yellow,magenta,cyan has the same white line,the black is ok.
    • 37556
    Re: Ricoh colour proc 651 line problem
    What, if anything have you tried?
    • floody
      • Mar 2017
      • 37
      do a sky shot in single colour to see which colour you have an issue with
      • mrwho
        Major Asshole!
        • 4299
        Post examples of each individual color.
        Mascan42
        Ibid
        • pythonas
          • Dec 2015
          • 14
          Thank you all for your replies..as you see i attach a file that has all the indivisual color(cyan-magenta-yellow-black)as i show with the arrow all colours copies except black has the same line at the same position.thanks33333.pdf
          • floody
            • Mar 2017
            • 37
            looks like your optic mirrors are dirty on the scanner, have you tried printing in colour? print out colour test page in service
            • pythonas
              • Dec 2015
              • 14
              yes i scanned these copies at an old mashine
              • floody
                • Mar 2017
                • 37
                well looks like your black PCU or dev unit is your issue, split the drum and dev and inspect them check for where and tear or damage
                  • 37556
                  Since the line is in cyan and magenta and not in yellow and black, my guess is the laser unit. There are two separate polygon mirrors on the polygon motor assembly. One is for black and yellow and the other is for cyan and magenta.
                  • RG1964
                    • Jul 2009
                    • 56
                    "One is for black and yellow and the other is for cyan and magenta."
                    Y is on the left and K is on the right. Large laserunit.
                    Make an image on the itb and check if you can see the line. Looks to me like a line from the ptr unit. Black doesn't look good also.
                      Originally posted by pythonas
                      Thank you all for your replies..as you see i attach a file that has all the indivisual color(cyan-magenta-yellow-black)as i show with the arrow all colours copies except black has the same line at the same position.thanks[ATTACH]36416[/ATTACH]
                      looks like to me you have issues with ALL colors including black... check the ITB.. make sure you clean contacts for all drums .. belt.. clean laser lens ..
                      you really should let us know what ALL you have tried to fix the issue ..
                      • pythonas
                        • Dec 2015
                        • 14
                        Maybe is not clear from the attachments but the yellow also has the same line.So we have the same line at the same place on cyan,magenta and yellow.what i checked until now is almost everything,lazer,dev units,drum units and transfer belt.The thing that makes me crazy is that the black has no line on it.i am waiting from your experience to understand whats the problem and i have this line to all colours but no at the black,thanks again.
                        • mrwho
                          Major Asshole!
                          • 4299
                          I'd check the underside of the Cyan PCDU for anything that might be rubbing on the ITB and causing the line.
                          Mascan42
                          Ibid
                            strange from your print samples I see lines on ALL color examples
                              measure from the first line down to the next showing of the line.. in the manual it should tell you what component is to blame... the repetitive ruler ( in mm ) is you best tool for repetitive marks in the manual
