MP C4503 K Quality Issue
  • david0161
    • Nov 2016
    • 14
    [CQ] MP C4503 K Quality Issue
    Hello all, hopefully I can find some advice on what could be causing my issue. Please look at the attached example.
    FW updated
    Printer & Copier Application memory clear
    K Drum/Dev unit
    IPU
    Imaging IOB
    PTR
    Re-seated all board harnesses.
    Cleaned laser glass
    Process control shows 1's across the board. At a loss for what the issue may be. Thank you in advance!
  • Gamut
    • Jul 2008
    • 216
    Re: MP C4503 K Quality Issue
    Suspect Black plastic "duct" missing from PCDU if you look at back of a colour unit you will see whats missing from your Black PCDU.
    • semi
      • Sep 2008
      • 195
      FW updated
      K Drum/Dev unit
      IPU
      Imaging IOB
      PTR
      Cleaned laser glass
      Looks like missing rear PCU cover-missing dev bais-or bad contact of the cover earth strap
      • copier tech
        • 8174
        I agree with the two posts, if that rear cover is missing or the tiny copper contact is bent out of position you get that exact issue.
        • david0161
          • Nov 2016
          • 14
          Appreciate the feedback and suggestions. The problem is now resolved.
          • copier tech
            • 8174
            Perhaps you could enlighten us on what was the solution?
            • david0161
              • Nov 2016
              • 14
              The technician had replaced both the K PCU and the Dev unit at the same time. Neither one of these parts are packaged with the rear cover "duct" and was missed upon replacement. Thanks again for the input! Moved a color rear cover to K and the issue jumped with K being fine. Surprised that's not included with either part!
              • semi
                • Sep 2008
                • 195
                It is now,the design of the dev unit has changed meaning you cannot use the old cover on the new dev unit.
                • copier tech
                  • 8174
                  Thanks for the update.
                  I hope you didn't replace all these parts just for a simple issue!?
                  IPU
                  Imaging IOB
                  PTR
                  • SargeNZ
                    • May 2012
                    • 263
                    An expensive service call! Hope you saved all that other stuff you pulled out.
