Scan to folder on different class IP
  • Azharuddin
    • Jun 2016
    • 33
    Hi all,
    I have an issue with scan to folder on my Ricoh mp 2851 machine. Machine works on one class ip but the pc 's are working with different class ip .
    But machine is printing without any problem.
    Note : updated the latest version of network support on machine.
    What should I have to do on my Ricoh.,,🙄
    Thanks in advance
    Sent from my XT1562 using Tapatalk
  • nqk
    • Sep 2010
    • 26
    Its Ricoh software error still i am also Searching but failed its a smb protocol error thats does not match with Windows 8/10 you should try on win 7 its works on it but some version still not working on win 8-10
    • Azharuddin
      • Jun 2016
      • 33
      Re: Scan to folder on different class IP
      Originally posted by terramobil
      If you scan to the hostname of the destination PC, you have to specify the DNS Server in "Network" settings, or try it with the IP address. Can you ping the destination PC from the machine?
      Ya i can ping the same class ip.
      But not the other class
      • Azharuddin
        • Jun 2016
        • 33
        Ya i updated the firmware to the latest one.
        But this issue is not with win 7 or 10 .
        • Codex
          • May 2008
          • 704
          try to setup your router for virtual lan on one port,, so you can setup different ip addresses.
          Memento Audere Semper
            • 37513
            This sounds like a problem with a Windows updates from about 1 year ago.
            • sodinet
              • Feb 2017
              • 11
              You can't ping other class ip???
              Only in the same network??
              I had a similar issue with a router. The machine can't reach the computers behind the router, but the computers can reach the machine.
              This is because the router haven't routing to the computers. This is a network issue.
              • Azharuddin
                • Jun 2016
                • 33
                Thanks mate.
                But in sharp machine it works. They recently installed Ricoh .
                  • 37513
                  Thanks mate.
                  I don't about Sharp, but maybe the Sharp allowed building a routing table. Ricoh does not. You could try building a routing table on the gateway/router.
                  • sodinet
                    • Feb 2017
                    • 11
                    Thanks mate.
                    Ok. How about network permissions?
                    I have a client that need the MAC address to fix a IP to it, and then give permissions to access to other networks.
