SPC252 Faint copies prints OK
  • copier tech
    • 8195
    [CQ] SPC252 Faint copies prints OK
    Hi all,
    I have been asked to at this one, an SPC252 that prints fine but copies are faint.
    Not really sure where to start in this one, I don't work on many SPC models, I mainly work on the office Ricoh range.
    Machine is only a few months old & has done few clicks.
    Any suggestions appreciated!
  • Gamut
    • Jul 2008
    • 216
    Re: SPC252 Faint copies prints OK
    Check if toner save enabled, affects copy but not so much print.
    Same on all the SP's.
    • copier tech
      • 8195
      This was exactly the issue, it made a dramatic difference turning toner saver off on copies.
      Easiest call ever, thank you for the tip! 😉
