Ricoh MPC3003 - Holding Prints?
  • K0D3R
    • Jan 2017
    • 3
    I've got a Ricoh MPC3003 that is holding prints by default.
    This becomes quite annoying when people have to walk over to the machine and manually tell it to print each job.
    I've been looking for hours and can't seem to find anything that would make this happen permenantly.
    Is there an option in the web admin or on the machine that causes this?
    • 8131
    Re: Ricoh MPC3003 - Holding Prints?
    Two main causes for this:
    In the printer driver go to printer properties, advanced settings, printing defaults & check job type is set to "normal print"
    Also if the user is trying to print a document on paper size or weight that is not loaded in the copier it wont print unless, as you say, the customer walks up & choses what paper try they want the device to print from.
      • 22999
      ... Also if the user is trying to print a document on paper size or weight that is not loaded in the copier it wont print unless, as you say, the customer walks up & chooses what paper try they want the device to print from.
      That's the one I was watching for. In situations where you're enduser is too ... um, busy ... to select a paper tray, a paper size or a media type, I will go through the driver properties and set up fit-to-paper, and a specific tray, so something prints every time. If that is unsatisfactory then they can make driver selections for themselves. =^..^=
      • NeoMatrix
        Senior Tech.
        • 3513
        I assume the MFD is set up for authentication and the PC software driver pass ID is set correct for each user ? Is the MFD set for "driver command" or device settings?
        Is this a very busy office for large print jobs?
        Is there a lot of PC files sent to the MFD and or waiting in the doc server print queue for normal print out? Is some one standing at the MFD and jumping the wait queue by pausing other peoples print jobs at the MFD?
        Is the doc-server default set for "delete files after X days"?
        HTH
        • K0D3R
          • Jan 2017
          • 3
          HTH
          I believe MFD was setup at one point, but was disabled.
          Not really very busy there were 30 jobs in the queue after 3 days.
          Yes doc-server set to 10
          • hdmr
            Helpdesk Engineer
            • Feb 2013
            • 51
            Are these jobs in the hold queue?
            As previously mentioned it could be the print driver being defaulted to Hold/Lock print or it could be a setting on the device for all jobs to be set to mandatory Hold.
            To check this follow these settings:
            • User Tools, (small button on control panel with a diamond and 123 written on it)
            • Printer Features,
            • Select the System Tab and navigate to the 2nd page selecting Next bottom right,
            • Restrict Direct Print jobs should be OFF
            If you find this option is on Automatically Store Jobs it will do as your suggesting.
            Hope this helps.
            • K0D3R
              • Jan 2017
              • 3
              I'll try that, thank you very much!
              • slot
                • 341
                on all new ricohs you can tell the copier to hold all print jobs by default I think it is in printer settings in user tools it not easy to find as it not described as hold all jobs I think you can also see it with the web browser
                  • 37397
                  One other thing that will cause a job not to print without user intervention is if the paper type in the paper tray settings of User Tools and in the print driver do not match exactly. There is a setting in User Tools where you can tell the printer function to use Driver/Program instead of machine setting. This will cause the machine to ignore the paper type and weight settings on the machine and assume that the user knows that the required paper is in the selected paper tray.
                    • 8131
                    Good info, where in user tools is this setting exactly?
                    • davel
                      • Oct 2011
                      • 1097
                      Originally posted by vga_man
                      Are you use USB 2 cable or usb1?
                      You should use USB 2
                      From computer control panel,printers properties check start printing immediately
                      Sounds to me that it is using network port.
                      • davel
                        • Oct 2011
                        • 1097
                        may be
                        so from system settings he can choose lan maximum speed
                        How does this stop the jobs being held.
                        • Brianneoe
                          • May 2015
                          • 318
                          user tools, printer features, system,.. poke around there and you will find it. The older Ricohs would only let you set driver command to the bypass. Now you can set all the trays that way if need be. Just a FYI, the old units came in with the bypass defaulted driver command but the new machines are defaulted machine setting. Its a great option if your dealing with Law firms and the like. Very few manufactures have this option and is a good selling point when your replacing a HP. Ricoh and HP are the only products that I know of that can do this. When sales upgrades a customer with another product and they are replacing a HP or Ricoh unit the dissatisfaction level goes up to a point where we have had to replace the machine with a Ricoh unit. The last thing a customer want to do when they send a print job,usually a envelope thru the bypass,is to now have to configure the machine to mach the size.
                          • NeoMatrix
                            Senior Tech.
                            • 3513
                            Any body else missing the below thread from this forum post ?
                            (See attached image of totally missing thread by Vga_Man).
                            I'm also seeing some old posts updated as current and some click likes/thanks repeated.
                            sorry for off topic.....
                              • 37397
                              [ATTACH=CONFIG]37092[/ATTACH]
                              Do you mean the post by van_man quoted by Davel? I thought that maybe vga_man had deleted it while davel was in the process of quoting it.
