MPC5502 adding PS3
  • mrfuser
    • 1622
    MPC5502 adding PS3
    Client has added a MAC to the mix and now we need to add the PS3 option to the MPC5502. I thought you only needed to remove the SD card in the upper slot and replace it with the PS3 card (appropriate for the MPC5502, to get it to work, but alas, nothing. Will not show as installed. PCL still shows as well as PDF, just can't get the PS3 to set up. Any thoughts?
  • tufbnme
    • 493
    Re: MPC5502 adding PS3
    MPc4502 5502 PS install.pdf
    • copier tech
      • 8195
      Is this new PS card you are using? (not borrowed from another machine)
      โ€‹
