dialing an outside line using access code
  • peakjohn
    • Jun 2017
    • 6
    I am having an issue with the mp 4055 and the mpc 4504 using the pause when in memory fax. For example when dialing to reach an outside line the customer should be able to dial 9 pause pause 555-5555. The pauses show up on the screen but there is no space when it dials the number. It works fine on onhook dial but not on memory. Older models never had this issue.
  • peakjohn
    • Jun 2017
    • 6
    Re: dialing an outside line using access code
    Has anyone run into this issue? and if so do you know of a solution. thanks
      • 23007
      As an alternate solution you might look in the fax service setting to see if you have something called "xxx milliseconds between dialed digits."
      I accidentally discovered this on a Toshy fax card the other day. =^..^=
