Sr-90 Booklet maker
  • captkirk
    • 39
    Sr-90 Booklet maker
    We have a SR-90 booklet maker that keeps jamming. We are running it on the stand alone mode. It seems to be jamming while it is jogging the sheets together. The side guides on the booklet maker seem to move out and then back into the paper, but at this time the paper goes under the jogging arm.
    We have checked all sensors and can see nothing that would be causing this. Nothing is in the way.
    It looks like something happened to the jogging part to us.
  • rthonpm
    • Aug 2007
    • 2847
    The SR 90 is a tough bird to try and troubleshoot. Have you tried running its own diagnostic programme to see where it says it has an issue?
    For whatever reason, sometimes running the diagnostic, then rebooting the cursed thing will bring it right back up to life with the issue disappearing. If it comes up with an error code then you'll at least have an area to start with.
    This is device really is a POS. I often thought when I had one of these in my territory that the thing should be called a Problem-atic instead of a Plock-matic...
    • Shadow1
      • Sep 2008
      • 1642
      If you can ever get one running right it's like the energizer bunny - but that's a BIG if.
      Had to do a paper size reset for that problem a while back. It's documented in the manual with pictures and detailed steps, but it uses that funky metal tool that's bolted down inside the cover, and it's really cryptic exactly where to put it, and how to insert it there. (I have a suggestion where to put it, but not in polite company)
      73 DE W5SSJ
      • captkirk
        • 39
        I made a mistake. It's the SR-85. Not the Sr-90.
        The SR-85 has no digital display.
        We have put a piece of mylar on the non operator side jogging guide. After watching it run for several copies it looks like the books are sliding under this guide.
        This has fixed the problem some what but is not where we want it to be. Not sure why all of a sudden the paper started going under this guide, it has been running great.
        It seems to me that the machine know joggs twice before the books get into the machine. We never noticed this before and I believe this is some of the problem.
        Is there a reset for the this machine?
        • Shadow1
          • Sep 2008
          • 1642
          Been a while since I've worked on an 85 but I had plenty of problems getting paper into them online, never had much trouble offline...
          Attached is the service manual from Ricoh - the reset procedure is on page 72.
          73 DE W5SSJ
          • Shadow1
            • Sep 2008
            • 1642
            73 DE W5SSJ
            • ffashe
              SR 85/TR 85 folding/stapling issues
              Help!!
              I have a Plockmatic SR 85/TR 85 Bookletmaker/Facetrimmer that seems to have suddenly gone nuts! It staples and folds about a quarter of an inch apart! Normally the stapling and the fold should be on the same line. When adjusted to fold correctly, the the staples are off and when adjusted to staple correctly then it folds at 1/4 of an inch off from the middle. I have tried everything I possibly can to fix this. Even called a technical repair company and the technician was as stumped as I am.
              Any ideas anyone?
              • Shadow1
                • Sep 2008
                • 1642
                Load the EEPROM defaults, then do the adjustments, then burn some incense and sacrifice a chicken - if that doesn't work make the whole contraption into a burnt offering...
                73 DE W5SSJ
                • Ed Ferretti
                  I have an SR85 that works fine, any interest in buying it?
                  • Ed Ferretti
                    I have an SR85 in great condition for sale, do you know of anyone interested?
                    • STIG5897
                      • Oct 2011
                      • 13
                      Re: Sr-90 Booklet maker
                      YEAH I WOULD MATE , I NEED A NEW BOAT ANCHOR.......... LOL
                      I FEEL ALL YOR PAINS GUYS I HAVE ONE AT THE MOMENT THAT FAILS THE PAPER SIZE RESET AND THERES NUFFIN IN MANUAL BOUT THAT ONE, THIS THINGS DONE A POWER OF WORK THOU ............
                      I THINK IT NEEDS TO BE SACRIFICED........... LOL
                      • Eselhirte
                        • Apr 2025
                        • 2
                        Hello, I am looking for the service manual for the sr90. Can someone please send it to me? I really need it, my booklet maker gives me the bm-156 error code an it doesnt do anything any more
                        eselhirte@protonmail.com
