MP C3004 PCU
  • nathan92
    • May 2015
    • 3
    [Misc] MP C3004 PCU
    Hello to all,
    someone told me that it's possible use the color drum of mp c3004 (d2392239) on mp c3003. D2392239 costs less than the MP C 3003 drum color (D1862239). Has anyone already tried and knows if it's true? Thanks in advance
  • HitMan
    • Aug 2015
    • 170
    Yeah works fine. You can also release the spring mechanism to stop wear on all models
    • aktasson
      • Feb 2017
      • 201
      Re: MP C3004 PCU
      Originally posted by nathan92
      Hello to all,
      Because this is the lifetime difference. D1862239 (3003) -> 270k / 100% and D2392239 (3004) -> 175k / 100%. I would not experiment in your situation If I were you.
      • asilkartal
        Re: MP C3004 PCU
        Hi Hitman,
        We can not do it.
        Have you changed MP C3004 color drum unit to MP C3003?
        Thanks in advance
        • copier tech
          • 8172
          Re: MP C3004 PCU
          • anothertech
            • 1771
            Re: MP C3004 PCU
            I have been using the 3004 drum for a direct fit replacement on the 3003's for a while now. No mods needed, slides right in. Works good, I don't know how long they last, I have not had one of the replacement drums go the distance yet.
            Quote "Yeah works fine. You can also release the spring mechanism to stop wear on all models"
            I have thought about this, I will try releasing the pressure spring on all of them, it should help with longer life of the drum units.
            • anothertech
              • 1771
              Re: MP C3004 PCU
              [QUOTE=anothertech;782368]I have been using the 3004 drum for a direct fit replacement on the 3003's for a while now. No mods needed, slides right in. Works good, I don't know how long they last, I have not had one of the replacement drums go the distance yet./QUOTE]
              I have only done this with the black pcu, I have not tried using the 04 color drum in an 03 yet.
              • fshead
                • 2376
                Re: MP C3004 PCU
                the spring you reference is that the lub bar pressure springs?
                The few mpc3003 drums i have taken apart i do feel there is excessive lub material broken up inside.
                • Gift
                  • Mar 2011
                  • 2459
                  Re: MP C3004 PCU
                  I totally would in case you have a service contract with low color volume. C3004 pcus are cheaper so it can make sense in case the expexted volume fits.
                  • aktasson
                    • Feb 2017
                    • 201
                    Re: MP C3004 PCU
                    Well then just do it like you want, good luck
                    • Athlontini
                      • Jun 2012
                      • 269
                      Re: MP C3004 PCU
                      Our company uses them, works great so far. We don't even order the c3003 PCU's anymore.
                      • COPIERMAN
                        • Jun 2009
                        • 559
                        Re: MP C3004 PCU
                        i was looking between c3004 and c3003 fuser fixing sleeve last four # are the same in both but the c3004 is cheaper was wondering if any one has tried using c3004 in the c3003
                        • copier tech
                          • 8172
                          Re: MP C3004 PCU
                          No these are not the same, no shutter like the 03.
                          • skinnyb
                            • Jul 2008
                            • 291
                            Re: MP C3004 PCU
                            Definitely Fuser is different. Pressure roller and bearings are interchangeable though and the drive gears.
                            Sent from my LM-V405 using Tapatalk
                            • COPIERMAN
                              • Jun 2009
                              • 559
                              Re: MP C3004 PCU
                              thanks for info we been using MPC3003 to put out in offices and have not purchase MP C3004
