Windows 10 SMB Scan to Folder MP 2852 Problem
  • copyaction
    • Oct 2007
    • 991
    #16
    Re: Windows 10 SMB Scan to Folder MP 2852 Problem
    Originally posted by fireater
    Win 10 has disabled SMB1
    see if you can re-enable SMB1 should work
    do you happen to have the procedure for that?
      • 37605
      #17
      It is a registry edit. This might help.
      See various ways to detect, enable, and disable the Server Message Block (SMB) protocol (SMBv1, SMBv2, and SMBv3) in Windows client and server environments.
      • rthonpm
        • Aug 2007
        • 2859
        #18
        https://support.microsoft.com/en-us/...ws-and-windows
        For Windows 10 you can just go into Add/remove programs and then Turn Windows features on and off. Just look for SMB1.0/CIFS File Sharing Support. Put a check in the box and then reboot when prompted.
        • gkalchik
          • Jul 2017
          • 19
          #19
          If the firmware is where it should be there is another thing you might try. I don't know if this holds true for Ricoh products but the area I work in now is mostly populated with Kyocera products. The problem I have been running into is setting up scanning with the Microsoft user accounts that Windows 10 seems to default to. When I add a local user account and give that user read/write permissions to the scan folder everything works ok.
          • PacketSniffer
            • May 2017
            • 21
            #20
            No one has asked if the OP is running Win10 Home Edition...
              • 37605
              #21
              It shouldn't make a difference. Or at least I have no problem setting up SMB scan to Win 10 Home, i.e. my own laptops.
              • sturmtrooper
                Copier Combobulator
                • May 2016
                • 587
                #22
                My work laptop has windows 10 home on it and I was able to scan to folder with an SP3510, MPC4000 and an MP6503.
                Is there something special that is supposed to be done first?
