Ricoh MP C4503 duplex jams
  • caffeinekid
    • May 2017
    • 25
    This unit is jamming post-fuser when running duplex jobs. Error in SP mode shows 7504-27 = 38 counts and 7504-52 = 46 counts. The paper stops as though it is not being properly diverted. I don't typically work on this model, so any insight would be appreciated. The gate itself does not appear to be warped and the sensors are all clean. Unit only has~ 100K total meter. Fuser looks good as well.
  • copier tech
    • 8174
    Re: Ricoh MP C4503 duplex jams
    Check the gear on the main door, top rear, this drives the duplex, when customer slam the door it bends the shaft, it can even snap off (nightmare to replace)
    Usually bending it back will resolve.
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Also check the operation of the duplex/bypass motor, I've had this die once. (It is the same motor that runs both, lower-rear side of the right hand door).
      • Mark Bbb
        • Jun 2012
        • 1662
        Is it the same with A4R?
        • davel
          • Oct 2011
          • 1107
          you mean SEFI
