MPC401 PCU mod?
  • Hadster
    • Aug 2011
    • 264
    MPC401 PCU mod?
    This may have been posted elsewhere but I cannot find it. I just started working with these and I would like to know if you can modify a K PCU for a color PCU? I ask because the part # is different but the PCU looks the same and looks like all you have to do is move the white clip in the rear to K. And, if you can mod the fuser out of a spc430dn to work.Thanks!!!!
  • Hadster
    • Aug 2011
    • 264
    Re: MPC401 PCU mod?
    Ok, I figured out that the fuser will work! Printer version is just missing jumper wire on Pin 2&3. and the cover (with 2 screws) beside the outside door has a notch that you have to shave off or replace with old fuser cover. Now, if I can just find out about the PCU's!
    • copier tech
      • 8172
      Re: MPC401 PCU mod?
      No you cant fit the K PCU as colour because these units have the dev unit built into them!
      • sturmtrooper
        Copier Combobulator
        • May 2016
        • 587
        Re: MPC401 PCU mod?
        But what if I just really really like cyan?
        • copier tech
          • 8172
          Re: MPC401 PCU mod?
          I think pink suits you better
          • Polarbear
            • Feb 2012
            • 1070
            Re: MPC401 PCU mod?
            Wait what?! You replacing a pcu with a fuser??
            Sent from my SM-G925F using Tapatalk
            Press the GREEN button!!
            • Hadster
              • Aug 2011
              • 264
              Re: MPC401 PCU mod?
              Come on man! READ the thread. I'll let everyone know if I figure out a way to mod the k pcu if possible.
              • Polarbear
                • Feb 2012
                • 1070
                Re: MPC401 PCU mod?
                If I understand you correctly: you need to be able to use the K units in the colour stations? Like with most other colour devices, the physical drums are the same, it is the dev units that will cause you headaches.
                So if you order the K unit and remove the dev unit, I am sure you can make it work?
                • ruben
                  The New Guy
                  • Oct 2012
                  • 1203
                  Re: MPC401 PCU mod?
                  The black PCUs have two metal pins that will stop you fitting them into the colour slots.
                  • sandmanmac
                    • 3981
                    Re: MPC401 PCU mod?
                    I haven't laid hands on any MP C401's yet. I'm glad to see they went back to the C300/400 design. I don't have many out, but they've been pretty good. I've tooled around with the PCU's and fusers a bit myself.
                    I've created a little cheat sheet for myself (attached). The Fuser mod is compliments of 'someone' here on CTN from some time ago that I found. I figured out the PCU mod on my own.
                    I don't know about the Black Drum only as Ruben talks about. I'll have to look into that, but colour to colour works
                    SP C430 to MP C300_C400.pdf
