MPC 5503 with SC 665-02
  • Roger67
    • Nov 2013
    • 84
    Hello,
    i have a allmost brandnew MPC 5503 who comes with a SC 665-02 right in the Start-Up-Procedure.
    In the Manual the Code means a Connection Failure between the BCU and the Picture IOB.
    I changed the BCU without success.
    Anybody has an Idea ?
    Cheers
    Roger
    Re: MPC 5503 with SC 665-02
    Originally posted by Roger67
    Hello,
    Cheers
    Roger
    I find when I have issues like that, reseating ALL connections of both PWB's helps.
    • Mark Bbb
      • Jun 2012
      • 1662
      if it is a new machine as you mentioned, Ricoh needs to take his responsibility and help you out.
      • Roger67
        • Nov 2013
        • 84
        Hi Folks,
        so i changed the IPU,BCU,EEPROM,IOB and the Harness between the BCU and IOB Board.
        I still have the SC 665-02.When i go in to the SC Mode,everything Comes in Japanese oder Chinese
        Languages.
        Puuuuhhhhh......
        Cheers
        Roger
        • TonerMunkeh
          Professional Moron
          • 3865
          Does it have lower paper trays or an LCT? If so, take the machine off it / them and try again.
          Hit it.
          • copier tech
            • 8174
            You could have an issue with the NVRam.
            Have you tried flashing ALL the firmware?
            • tufbnme
              • 493
              Bulletin from Ricoh, hope it helps
              rfg059249.pdf
              • Roger67
                • Nov 2013
                • 84
                Hello Folks,
                thanks for your Help,but i still have the same Problem.
                When i pull out the Toner Cartriges i can update the Firmware and can enter the Service Mode.
                In this stage ( Toner is out ) when i put the Toner in, the Maschine cant recognize the Cartriges.
                When i restart the Maschine,with the Cartriges pullt IN , i get the SC665-02 again !
                Do you think the Problem is in the 4 ID Chips Board,or maybe the controll-Unit of them ? ( each of this ID-Chips are located at the front of the Toner cartriges,right ? )
                This is realy strange !
                Cheers
                Roger
                • Roger67
                  • Nov 2013
                  • 84
                  Folks,
                  Wonder Happens............
                  I changed all the Toner Cartridges and now....the Maschine runs well !!!!!!!
                  I dont no why,but it seems that maybe all the Toner Cartridges have some wrong informations on the Chip.
                  Now i am checking this Baby......it runs well.
                  Thanks for your Input
                  Cheers
                  Roger
                  • sturmtrooper
                    Copier Combobulator
                    • May 2016
                    • 587
                    Folks,
                    Cheers
                    Roger
                    My guess is that one or all of the toner bottles had bad RFID chips. Or maybe the machine damaged them. If this problem repeats you may have to look at the RFID sensor board on the machine.
