SPC830 Fuser Unit in an MPC5502
    • 8236
    [Misc] SPC830 Fuser Unit in an MPC5502
    Quick question i've been fitting the SPC830DN Transfer Belt Unit to the MPC5502 (This unit is a lot cheaper than the belt & cleaning unit)
    My question is has anyone tried fitting the SPC830DN fuser unit to the MPC5502 ?
    As again the complete 830 fuser is a lot cheaper than the 5502 sleeve & film.
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: SPC830 Fuser Unit in an MPC5502
    http://www.copytechnet.com/forums/ri...ing-units.html
      • 8236
      Thanks for steering me in the right direction! 😘
      • Imprestik
        • Aug 2012
        • 297
        Just a bit of a update on this.
        Only use the fuser maintenance kit of the 4502/5502's
        Do not use them on the 3002/3502's.
        Fusing lamps are different and will cause SC553 on a 3002/3502, while it will work to start off with it wont last long....
          • 8236
          Thanks for the update, which kot do you use for the MPC3002/4502?
            • 8236
            My colleague recently fitted the SPC830N fuser kit 407097​ to an MPC5502 & so far no issues, maybe because we use 220v it is compatible?
            • Manuel V
              • Feb 2022
              • 4
              The fuser unit on an SP c830DN wears out quickly using 100 lb (300g) paper in my experience from 20 to 30,000 copies. MP c5502 fuser, should I expect the same life time?
              My SP C830DN printer at less than 100,000 copies has three fuser blown. Where can I buy the fuser band, which is the only thing I need to change?
              • Gift
                • Mar 2011
                • 2459
                Kind of all fusers using a sleeve on a static core don't like high amounts of thick paper, especially if you feed it SEF. You can buy the sleeve from katun I guess - I tried that once and it worken but didn't bother again.
                • fshead
                  • 2378
                  You must change more than the FUSER BAND>>>i think you mean fuser sleave.
                  there is a cotton lubricating pad that attaches with a lot of small screws.
                  You need the sleave,the cotton lub pad and the high temp oil or greas,whatever they call it.
                  I would also change the gears on the side.
                  pressure roller needs to be checked too.
