Incompatible usb cable ? MPC300
  • digicor
    • Jul 2008
    • 1159
    This message is on the machine, it wont come to ready, print or fax,Client does not have any usb hooked to it, I disconnected the fax board, same message, i disconnected the USB cable from the board in the back, same message
    anyone have this happen and what fixed it?
    thanks
    • 37556
    Re: Incompatible usb cable ? MPC300
    Cable no, device yes on some older models with a USB slot for scanning. The small PCB the the connector was mounted on was defective.
    • digicor
      • Jul 2008
      • 1159
      remedy?
        • 37556
        Originally posted by digicor
        remedy?
        For me since the customer was not using the scan to USB and did not want to pay for a new board, I just disconnected it.
        • digicor
          • Jul 2008
          • 1159
          ok kool thanks ill just do that , your talking about the usb on the panel correct? i cant disconnect the one on the print controller,
            • 37556
            What I was working on was an older machine that had a USB connector on the left side panel near the front. Can't remember the model. It was over a year ago.
            • digicor
              • Jul 2008
              • 1159
              yeah thats it , thanks for the heads up
