MP 201 WIM Password
  • ABS tect
    • Sep 2013
    • 511
    MP 201 WIM Password
    Can't login to my 201 under admin or supervisor. I did 5-846-046, 5-801-10 & 11 and still nothing
    I thought 5-846-046 would work cause it always has in the past but i'm stumped...any ideas?
  • ricmartinho
    • 142
    Re: MP 201 WIM Password
    Have you tried doing the SP setting in PP Mode?
    • ABS tect
      • Sep 2013
      • 511
      Not sure what you're saying sorry... Could you explain more?
      • ABS tect
        • Sep 2013
        • 511
        I did 5-846-046 in Factory service mode, thats the only way you can even access it. Any other ideas?
          • 37062
          You may have a corrupted address book.
          Try the following:
          1. SP 5846-051 Backup all address books
          2. SP 5846-050 Initialize All Address Books
          3. Cycle power
          4. Update/reload all firmware.
          5. SP 5846-052 Reload All Address Books(if old address book data is still needed).
          • ABS tect
            • Sep 2013
            • 511
            Try the following:
            3. Cycle power
            I did that...no go. It does say address book data error. Any other thoughts? Don't know if doing an 5801 would help but cant really cause i don't have the birth certificate
              • 37062
              If it occurred while backing the address book, go ahead and initialize. If that fails, then you have defective memory or if there is a HDD it needs to be replaced.
              • sandmanmac
                • 3973
                I'd "Like" your post if I could Tim
                I was wondering that myself.
                Otherwise, this might shed some light:
                MP171SPF - Address Book Data Error
                • SargeNZ
                  • May 2012
                  • 263
                  There's no HDD out of the box on these machines, the Address book data is stored on a part of the internal memory.
                  • ABS tect
                    • Sep 2013
                    • 511
                    Bummer.... Alright thanks guys... Guess I have to switch the controller board. Doesn't seem like I can do much else. Thanks!
                      • 8121
                      Before replacing any hardware its always a good idea to update ALL the firmware modules, nothing to loose.
                      • ABS tect
                        • Sep 2013
                        • 511
                        Following up on a question about the Address Book Data Error...I have been finding lately a lot of machines on the scanner function switches to the number of the user rather than just the SMB folder path. so it shows "001" and their name rather than "\\PATH\SCANS" or whatever it may be. Also there is a telephone in the top left rather than it saying ready. Any ideas as to why this is happening? I have just corrected it (temporarily of course) by shutting of the machine and powering it back on.
                        • sturmtrooper
                          Copier Combobulator
                          • May 2016
                          • 587
                          If you look at it it is probably alternating between the phone icon and "call service" if the machine has no service telephone number programmed into SP mode it won't show a number next to the phone icon.
                          • ABS tect
                            • Sep 2013
                            • 511
                            Yes but why would it be needing to call for service in the first place?
