problem with image cyan qulity mpc2003
  • en.
    • Jul 2014
    • 124
    hi all
    i have this issue in ricoh mpc 2003
    first its not give me cyan
    and i replaced development unit and its give bad image quality like attachment file
    i did this action
    1- development unit has been replaced
    2- iob image engine has been replaced
    3- high voltage board has been replaced
    4- image transferviber image 2003.jpg belt replaced
    5- laser unit replaced
    but the problem not solved ...any one can help me with this issue
    regards
    • 37533
    Re: problem with image cyan qulity mpc2003
    Sounds like you have replaced just about everything that wouldn't cause the problem. Now try the item that does cause the problem, the drum unit.
    • copier tech
      • 8174
      Yes why would you not change the drum!?
      As a test simply swap it with one of the other colours (all 4 the same)
      • timmi
        • Jul 2017
        • 11
        Replace drum unit
        • en.
          • Jul 2014
          • 124
          thanks for your responding
          i replaced drum unit but its same problem
          • totoro
            • 568
            Switch the drum with another color because that certainly looks like a charge issue to me.
            Totoro
            • copier tech
              • 8174
              When you replaced the cyan dev unit did the first few copies come out OK?
              Also check the rear cover is on the PCDU
              • FrohnB
                • Jul 2017
                • 1919
                Run in to that before, forgot to put rear cover back on PCU when replaced (the one with the copper contact plate), and gave me weird issues like this.
                Omertà
                • tufbnme
                  • 493
                  Yep, drum unit. Glad I'm not paying for the parts.
                  • tufbnme
                    • 493
                    First time I replaced the drum I forgot this too, weird how it causes issues, just a plastic cover. Except it gave light images.
                    • copier tech
                      • 8174
                      Its not just a plastic cover, it has a dev bias contact attached to it!
