MP2501 clogged cleaning unit.
  • Voltageza
    • Jun 2017
    • 71
    Hi
    Any of you guys have come across mp2501 cleaning units getting clogged. The spiral is turning. I have replaced the complete PCU but now this unit is doing this as well.
    Any ideas??
    • 37533
    Re: MP2501 clogged cleaning unit.
    Are you sure that the coil is not turning? What I have seen is that paper lint will build up around the coil and clog to exit hole. Remove the drum and clean the recycler.
    • COPIERMAN
      • Jun 2009
      • 559
      did you do a reinitialize after installing new developer unit.
      • Voltageza
        • Jun 2017
        • 71
        Hi
        The spiral turn with the drum if i am correct. I have cleaned the spiral 3 times before changing the complete PCU unit. Now its clogged again after 12000 copies.
        • davel
          • Oct 2011
          • 1107
          You may be using bad toner, is it ricoh
          • Voltageza
            • Jun 2017
            • 71
            Yes it is.
