Ricoh c305
  • Myshkin
    • Aug 2025
    Ricoh c305
    Friends, Please, came the firmware Ricoh C305.
    On the screen - Error CC554-00
  • COPIERMAN
    • Jun 2009
    • 559
    Re: Ricoh c305
    MPC-3502 sc554-00(holy sh..!)
    paste in browser and read thru will tell how to reset copier.
    • sandmanmac
      • 3981
      Re: Ricoh c305
      Wrong machine
      • Myshkin
        Re: Ricoh c305
        Wrong machine, no firmware C305
        • arahael
          • Mar 2013
          • 97
          Re: Ricoh c305
          sc reset, inspect fuser...
          • Myshkin
            Re: Ricoh c305
            fuser replace , sc reset. ......
            need firmware
            • Zaxxon
              • 608
              Re: Ricoh c305
              need firmware
              Are you a robot?
              We come in peace!
              Please start you post with brand, model, problem.
              • copier tech
                • 8172
                Re: Ricoh c305
                Enter service mode enter SP5810 - Execute & re-boot
                If the error returns replace the fuser unit & try reset again.
                  • 37532
                  Re: Ricoh c305
                  Just be sure you enter the correct SP number, 5810. If you transpose the last two digits, you will create and whole new bag of problems
                  • copier tech
                    • 8172
                    Re: Ricoh c305
                    If you're unsure check it says "Fuser SC Reset" in the top left corner
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      Re: Ricoh c305
                      SC 554 you well need the reset fuse in the fuser unit or new fuser
                      It well not clear without this
                      Regards Mark
                      • copier tech
                        • 8172
                        Re: Ricoh c305
                        If the sleeve is not damaged just replace SC554 Fuse M0264371
                        • mrwho
                          Major Asshole!
                          • 4299
                          Re: Ricoh c305
                          Hello there.
                          How did you manage to solve this? Replaced the fuser (sleeve was destroyed), replaced the bicu (as per the manual) and firmware is up to date. Still sc554. And yes, it's a mpc305 (a4 machine).
                          Cheers!
                          Mascan42
                          Ibid
                          • copier tech
                            • 8172
                            Re: Ricoh c305
                            Originally posted by mrwho
                            Hello there.
                            Cheers!
                            You also need to replace the fuse
                            • mrwho
                              Major Asshole!
                              • 4299
                              Re: Ricoh c305
                              Fuse? Never noticed that mpc305 had any fuse... Where does it connect to?
                              And why doesn't the manual mention it, just telling to replace the bicu?
                              Mascan42
                              Ibid
