Aficio MPC 3300 tray 1 lift problem
  • COPYDOCAZ
    • Mar 2015
    • 110
    [Misc] Aficio MPC 3300 tray 1 lift problem
    When we install the tray the lift motor runs and the tray lifts about 1/2 in then runs back down, have replaced the lift motor. The strange part is no error code, no jam indication just the add paper indicator stays on doesn't even blink.
    the other trays are all working and the machine is not down.
  • Hadster
    • Aug 2011
    • 264
    Re: Aficio MPC 3300 tray 1 lift problem
    In paper tray look for bent or loose paper lift lever. I've seen that several times before.
    Sent from my Nexus 6 using Tapatalk
      • 37488
      As paper tray is lifted, the paper out sensor is not detected within the allowed time after the lift sensor is activated. This causes the machine to think the tray is empty. As Hadster said it could be caused by a warped lift tray, back corner higher than the rest of the tray. It could also be caused by about 10 or more sheets of paper in the stack having the back corner bent under making the stack higher on that corner. Other things to check are the lift sensor and the out of paper sensor.
      • COPYDOCAZ
        • Mar 2015
        • 110
        Thanks I'll try that
