ricoh mpc 3003 error SC312.01 problems
  • Jedi Ben
    Senior Engineer
    • 79
    Hi All
    it relates to a problem on blk drum charge. pcr.
    changed these parts and still coming up with code. any ideas???
    i.o.board
    hvp board top back right
    dc psu bottom right
    controller green boards
    the spring connector at back of machine touches the pcr in blk pcdu drum is ok (same as other colours) im getting continuity from that pin to the hvp board back top right.
    pulling my hair out with this one
    ben
  • sandmanmac
    • 3981
    Re: ricoh mpc 3003 error SC312.01 problems
    ben
    In my opinion the only way to be truly be sure if an error related to the PCU is not caused by the PCU itself, is to try another one, and if I'm understanding correctly, you've not done that yet.
    It would have been the 1st thing I swapped before I went on to circuitry
    • copier tech
      • 8172
      I agree, you replaced all parts except the most likely item, the black PCDU.
      Also update the firmware,
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Check charge roller case assy these sometimes breaks then one side of charge roller comes away from drum.
        Regards Mark
        • Jedi Ben
          Senior Engineer
          • 79
          Hi Guys.
          i should of put that i changed the pcr then pcdu blk on top off my list. thats the obvious field to go through before pcb changes. i managed to find the fault.
          It was done to a blown mini transformer on the HVP-CB pcb. I replaced the board. it does the pcr and dev charge for each colours.
          sorry on late reply
          • TonerMunkeh
            Professional Moron
            • 3865
            Damn, I had an MPC306 do this to me yesterday, it was the HV board too.
            Hit it.
