block system settings / usertools
  • djremixer
    • Feb 2014
    • 18
    hi
    Is it possible to deactivate the settings menu on a smartpanel ex. MPC4504
    only when you log in as admin
    a bit like adresbook with extended security.
    reason: a employer/student can still see ip settings and/or print config page and connect his laptop , install drivers and print without restrictions!
    cheers
  • copier tech
    • 8169
    Re: block system settings / usertools
    If this is a college/school set up user codes for print, this way only users with a code set in the print driver can print and/or copy.
    For extra security turn on admin authentication & set a password this stops anyone from changing any machine settings.
    • djremixer
      • Feb 2014
      • 18
      I know this..... but client works with papercut NG so no user codes
      this is a missing link for Ricoh.....hide settings menu if your are not administrator
      • copier tech
        • 8169
        If papercut is installed correctly only users with a papercut licence/login should be able to release their print jobs.
        The papercut embedded app on the machine will reject any print jobs not authorised from the papercut server.
