SC670 Mpc2550
  • finhocamargo
    • Mar 2015
    • 23
    [Error Code] SC670 Mpc2550
    good night, I have a machine that takes a lot to call, when it appears with code sc670 and I can not enter the technical mode to cancel, can someone help me?
    I thought about updating it, would that solve it? or is the BICU board bad?
  • jonhiker
    • 661
    Re: SC670 Mpc2550
    An SC670 code is a controller error. You can try unplugging the hdd and see if it will boot with limited functions. You may need to replace the controller board and the ipu as a set.
    • copier tech
      • 8172
      Re: SC670 Mpc2550
      Yes sounds like a controller issue, I would first try updating the fw, if it will not boot off your fw sd card then I would replace the controller.
      However you could also try "reseating" all the controller connections, inc ram etc nothing to loose.
      • finhocamargo
        • Mar 2015
        • 23
        Re: SC670 Mpc2550
        the problem is that it is not letting me enter the simulation to clear the settings
        • finhocamargo
          • Mar 2015
          • 23
          Re: SC670 Mpc2550
          I downloaded the firmware update, I'll try to do it today
            • 37532
            Re: SC670 Mpc2550
            That is because is a controller boot error, not a fusing error. The error code cannot be cleared through SP mode. You must correct the cause of the error. Once you have done so, the error will be gone.
            • finhocamargo
              • Mar 2015
              • 23
              thank you
              • finhocamargo
                • Mar 2015
                • 23
                Re: SC670 Mpc2550
                Good afternoon, I've tested the boards on another machine and they're all working.
                DRB, BCU, CONTROLLER and HDD.
                help!!!
                • bob marley
                  • Jan 2012
                  • 1339
                  Re: SC670 Mpc2550
                  DRB, BCU, CONTROLLER and HDD.!
                  check the connection between the BCU and controller
                  Live for yourself and you will live in vain. Live for others, and you will live again
