Ricoh MPC4502 fixing films.....
  • Vintage tech
    • Nov 2017
    • 50
    Hi,
    have any of you out there sourced a good aftermarket fixing film/sleeve for the MPC4502/5502 copiers. I have fitted some that work OK, but give a "feathering" effect on the solids. They are OK if you only print text but if the user prints colour the solids are not good enough. I guess some would say just fit an original, but in the UK Ricoh charge silly money for a part that almost never makes life, so re filming a unit (as is possible with most other brands) would be a good alternative.
    Steve
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MPC4502 fixing films.....
    They do make life if you replace the stripper plate and the pressure roller at the same time.
    Hit it.
    • Elmo
      • Feb 2010
      • 541
      Ricoh D1444033, Sleeve Fusing Unit,
      i have seen just the sleeve's for sale on the likes of ebay but haven't used any
      Iam sure there are a few bulletins about the 02 fuser's
      They may help
      iam sure someone may be able to recommend a non original fuser sleeve supplier
      I Used To Live To Fix Things Now i Fix Things To Live
      • copier tech
        • 8176
        The latest fuser sleeves do last PM life, in fact they now go beyond life.
        • tufbnme
          • 493
          The fixing film assembly(D1444272)is not expensive and less hassle than trying to replace the film. They will go to life and beyond.
          Replace the LFR at the same time too.
          • Zeldaman
            • Mar 2011
            • 946
