Ricoh mpc 3502 dead machine.
  • ahson1989
    • Aug 2017
    • 23
    [Dead] Ricoh mpc 3502 dead machine.
    Hi. My machine not working i check the cable. All the fuse on the power supply is ok. But machine is dead . Power not coming at all . Even no notification light on the panel. Please help.
  • bob marley
    • Jan 2012
    • 1339
    Re: Ricoh mpc 3502 dead machine.
    try with an other PSU
    Live for yourself and you will live in vain. Live for others, and you will live again
    • Adween02
      • Aug 2017
      • 6
      Have u try other psu?
      Sent from my WAS-LX2 using Tapatalk
      • tufbnme
        • 493
        Try trouble shooting, that's what technicians do.
        • copier tech
          • 8174
          Yes first check that you have correct voltage entering the PSB (220v/110v depending on country) then the correct voltages (if any) exiting.
          • fshead
            • 2376
            did you ck the outlet?
            • ahson1989
              • Aug 2017
              • 23
              I replaced the power supply . Machine ia working now. Thanks to all
