Mp301 fuser same as?
  • mrfuser
    • 1622
    Does Anyone know if the fuser in the MP 301 is the same as a any other machine like at 1515
  • eddy out
    • Oct 2016
    • 359
    Re: Mp301 fuser same as?
    nope, it is not. bigger press roller and the hot roller is substantially different, too. Usually the only parts needed are AE011131 hot roller and AW100088 thermistor to repair.
    • The CopyDoc
      • Oct 2012
      • 19
      I rebuilt a couple of them and there were only a couple parts that crossed over from the MP 161, 171, 201, as i recall it was the thermistor that was the same, everything else was newer, rollers, bushings, gear, picker fingers, etc....
      • sturmtrooper
        Copier Combobulator
        • May 2016
        • 587
        Same thermistor. But they have bearings instead of bushings. The press roller is quite different. Keep a good supply of the thermistors and hot rollers because the thermistors deeply suck and eat the hot rollers.
