What to expect from a MPC3503?
  • fshead
    • 2376
    HI
    I am looking to confirm these boxes are NOT going to be a headache to place..
    Looking at some lease returns with about 100k to 150k..
    Did the change the fuser design Again?
    anything good or bad appreciated as I need to move one way or the other.
    thanks
    • 37560
    Re: What to expect from a MPC3503?
    The most important thing with the 03s is to make sure it is update on all firmware.
    One other thing is to keep doc feeder feed belts in stock as they have a tendency to destroy them.
    • fshead
      • 2376
      thanks
      how bout the fuser unit?same as the 02s or better?
      i see the mandatory FW posted here and will recheck previous posts..
      • anothertech
        • 1771
        Now that the 02's have been updated with new style fuser film and firmware they are very good. The 03's are as good as the updated 02's
        • fshead
          • 2376
          thanks
          I guess the drum interchangeability like earlier models is over?
          do you have to pull the charge roller out and "MOD" like the earlier models?
          • mrgene
            • 53
            can you reset the fuser codes with out a reset fuse ?
            • fshead
              • 2376
              cant say but just make a reset jig with a small door switch,wire and thermister end connector..........
              very easy..
              I plan on copying the nvram on all my c3002s and c3003 i sell.
