Does not respond when printing
  • bahaa
    • Jul 2025
    Hi how to update software
    ricoh mpc 4500
  • copier tech
    • 8164
    Re: Does not respond when printing
    Not printing, so what have you done so far? Can you open the WIM page?
    • vga_man
      • 78
      ricoh mpc 4500
      If it's not printing try to update driver definition on computer. If you are using pcl6 , try to change it to rpcs driver.
      The second stip is to clean ram...
      • tufbnme
        • 493
        If your updating the driver use the PCL universal, forget the RPCS.
        • david0161
          • Nov 2016
          • 14
          Configured using WSD or TCP/IP port? User codes enabled?
          • vga_man
            • 78
            Thanks alot
            That's depending on which driver Works great with printer...
            I've mp3350 works ONLY with rpcs driver 😔
              • 37513
              Thanks alot
              Then you need to install the Printer Enhancement Option.
