MP 301 after updating does not configure network and blocks
  • Guticopy
    • Oct 2017
    • 10
    Hi everyone
    In MP 301, after updating all the firmware: network, scanner, systen copy, engine ... etc I can not change the IP of the machine from the panel: User Tools / System Settings / Interface Settings / Network, press on the screen the Network button the machine blocks, does not respond to any key, it must be turned off directly.
    By WIM if it can be configured.
    Update has not been good or maybe some, I do not know which of them
    The same thing happened in 2 machines after upgrading.
    Someone knows what has produced this and how to solve it.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: MP 301 after updating does not configure network and blocks
    Unfortunately it sounds like you have installed the wrong firmware or not installed all firmware modules together and there is a conflict. Below is a list of all the newest firmware modules, compare them against what's on these machines and find out what is wrong / missing.
    aics aics GEN ( all ) D6605780 Ver.00.20.00
    Bank_POHNPEI1 Bank_1 GEN ( all ) D6615500A_bank1 Ver.01.010:02
    Bank_POHNPEI2 Bank_2 GEN ( all ) D6615500A_bank2 Ver.01.010:02
    browser D6595780F Ver.1.08.0
    Engine GEN ( all ) D1275770D Ver.1.04:05
    EXJS GEN ( all ) D6595782E Ver.1.18.00
    Fax GEN ( all ) D1275784M Ver.10.00.00
    Font EXP Font EXP GEN ( all ) D1275800 Ver.1.00
    GWFCU3.5-7(WW) GEN ( all ) D6555570L Ver.09.00.00
    Java VM v10 for eDC GEN ( all ) D6405748A_edc Ver.10.27.04
    Java VM v10 UpdateTool GEN ( all ) D6405748A_upd Ver.10.27.04
    Network Support GEN ( all ) D1275791P Ver.12.36.1
    NetworkDocBox NetworkDocBox GEN ( all ) D1275792F Ver.2.02
    OpePanel USA_ASI_KOR D1271498C Ver.1.04
    OpePanel.EXP EUR_CHN D1271491P Ver.1.24
    Option Netware Option Netware GEN ( all ) D6595781 Ver.12.09
    PCL GEN ( all ) D1275795L Ver.1.14
    PCL Font PCL Font GEN ( all ) D6415758A Ver.1.13
    PDF GEN ( all ) D1275798D Ver.1.04
    Printer GEN ( all ) D1275793L Ver.1.11
    PS3 PS3 GEN ( all ) D1275797A Ver.1.00
    PS3 Font GEN ( all ) D6415763A Ver.1.11
    RemoteFax GEN ( all ) D1275785E Ver.03.00.00
    RPCS GEN ( all ) D1275794C Ver.3.12.24
    Scanner GEN ( all ) D1275786H Ver.01.09
    System/Copy GEN ( all ) D1275780Y Ver.3.24
    Web Support GEN ( all ) D1275787P Ver.1.13
    Web Uapl GEN ( all ) D1275788F Ver.1.05
    Hit it.
    • Guticopy
      • Oct 2017
      • 10
      Thanks for the info.
      Problem solved. Indeed the blockade was caused by the lack of updating of one of the modules, specifically OpePpanel.
      Updating all the modules except this, caused the problem of blocking the machine to be outdated and try to configure the network from the panel of the machine.
      • Chimiscuilo123
        • May 2023
        • 4
        some tutorial or something like to solve it I have the same problem with the ricoh mp 301 sp when pricenar the network button is blocked the computer
        • sandmanmac
          • 3979
          You just "quoted" the solution. There is a firmware conflict.
          You need to update the F/W.
          Obviously you're an end user, so you either need to contact a tech to do that, or download and run the FREE F/W update tool
          • Chimiscuilo123
            • May 2023
            • 4
            What happens is that in my city, there are no technicians, and the Ricoh application for firmware doesn't work via USB, only through the network. Since I can't connect to the network, I can't update it. The other option is through the SD card, but I don't have the firmware files.
            • sandmanmac
              • 3979
              Then what led to this situation you're in, because it doesn't happen on its own
              Did you buy the machine like this, or what? If so, I'd be taking it up with the seller.
              • Chimiscuilo123
                • May 2023
                • 4
                What happens is that I provided a computer equipment repair service, and they recommended me for the job, but I have been researching and it led me here.
                • sandmanmac
                  • 3979
                  Determine the current IP address of the machine either by printing a configuration page, or otherwise.
                  Connect your laptop to their Wi-Fi, then connect your laptop directly to the MFP using an ethernet cable.
                  Set the static IP Address on your laptop for that hard-wired connection to something that matches the range of the IP address on the machine.
                  Then you can specify the IP address of the unit to be updated within the Update tool program and the updates will be downloaded over wi-fi and installed.
                  I just experimented with this setup on a machine that I have at my office and it worked.
                    • 37372
                    GO into System SP to SP 7992-005, Diagnostic Report, export it to a memory device and post that file here so that we can see what firmware levels are installed. Also let us know what JAVA apps if any are installed. There is an outside possibility that you have an app installed that requires Custom Firmware. If that is the case, you need to install that custom firmware after every firmware update. Or if the JAVA app was only needed for the previous owner, uninstall the app.
                    • sandmanmac
                      • 3979
                      Good Advice.
                      It reminded me of the fact that the Update tool WILL NOT work, nor will the package update, if there is any custom F/W installed.
                      In that case, you have to, at a minimum, install a non-custom version of that specific module (Ie: System/copy) which, as far as I know, would have to come from an authorized dealer.
                      I ran across this just recently myself with a new customer.
                      • Chimiscuilo123
                        • May 2023
                        • 4
                        When you want a good beer in a ranch in Mexico, you can come visit me hahaha. I was able to fix it, thanks handsome.
                        • sandmanmac
                          • 3979
                          Great.
                          Glad I could help
                          • Copyworks
                            • Sep 2010
                            • 6
                            I realize this is an old thread but I have the same machine with the same problem, in reading here I think I Need to update the Ope Panel , but I Have no way of downloading the module by itself, My update from the Ricoh website didn't update it and left it at ver 1.16. can anyone help me get the latest Ope Panel/ Thank You
                            • GIUBOSS
                              • 1389
                              Did you do exactly as described above with the RFUT tool, separately from the network?
