af 2018
  • Gab
    • Aug 2015
    • 671
    af 2018
    can i use af 1500 fuser unit on 2018 machine?
  • Zeldaman
    • Mar 2011
    • 946
    Re: af 2018
    Hi there!
    No, the 2018 has 2 heaterlamps.
    Greetings...
    • laitang
      • Nov 2012
      • 627
      Re: af 2018
      Yes! it the same.
      • fshead
        • 2376
        Re: af 2018
        Originally posted by laitang
        Yes! it the same.
        try it
        worse that can happen is it codes out...
        I remember mixxing up the 27cpm b/w OLDER series UFR and the rollers were a different thickness
        and would blow fuser codes...
          • 37529
          Re: af 2018
          There were 2 different fusing units that have been used with the 1500. The original unit and the RoHS compliant unit. The part number for the RoHS compliant unit is exactly the same as for the 2018. The part number for the hot roller is the only change.
