MPC 4503 - ardf DF3090 - j16
  • fdmarty
    • 18
    [Jamming] MPC 4503 - ardf DF3090 - j16
    Hi Everyone!
    I have this problem i can't solve. Ardf jams every 5/10 sheets.
    Tried to change Roller Ass'y, Board and sensors, firmware df3090 but
    it still have trouble. Can someone help me?
    Thanx.
  • solorajder
    • Jul 2010
    • 106
    Re: MPC 4503 - ardf DF3090 - j16
    DF3090 is problematic from begining. I have the same problem on MPC 2003 and MP3554. The costumer and I accept that I can't do any more else, we have to live with that.
    Sent from my I9195I using Tapatalk
    • copier tech
      • 8169
      I disagree this is a great DF I have 100's out that I never have issues with!
      Have you tried changing the DF buckle settings in SP mode?
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        Have you tried the newly modified feed assembly (D684-2101)? Ricoh have changed the material for the rollers inside the belt to increase contact with the paper.
        I have had many registration sensor jams on these DFs caused by the original feed assembly, and have had no returns since fitting the new one.
        • techsass
          • Dec 2010
          • 248
          I have to agree with Ruben. It's a pretty reliable DF, but like anything mechanical it does have a few quirks.
          We don't know what jams you're getting, but one of the weird things I've run into is that the Registration sensor bracket gets bent. I don't know how this happens, but I've seen it on at least 3 machines.
          • aktasson
            • Feb 2017
            • 201
            Originally posted by fdmarty
            Hi Everyone!
            Thanx.
            My suggestion would be to check df firmware first. It should be installed Version: 01.330:03. Then you install Mylar if not on df, P/N: D6842314 AD:SEPARATION SUB-UNIT and P/N: D6842313 SHEET:SEPARATION SUB-UNIT.
            And check the RTBs for the df3090.
            Good luck!
            • solorajder
              • Jul 2010
              • 106
              Thanks. I searched again about modifications and I found that there is a new firmware and this RTB 244040. Now I have hope again that maybe Ricoh finaly found the solution.rd244040.pdf
              Tapatalk Cloud - Downlaoad File rd244040.pdf
              • copier tech
                • 8169
                Thanks. I searched again about modifications and I found that there is a new firmware and this RTB 244040. Now I have hope again that maybe Ricoh finaly found the solution.[ATTACH]38776[/ATTACH]
                Thanks for the info
                • fdmarty
                  • 18
                  Thanks for the info lads, i let you know if i find the solution with One of your advices.
                  Inviato dal mio iPhone utilizzando Tapatalk
                  • Techconnect
                    • Jan 2018
                    • 15
                    Rough up one-way bearing section of shafts with emery cloth... maybe clean one-way bearings with cloth suck in needle nose pliers
