mpc2504 gMAIL
  • ATSBMCO
    Technical
    • Oct 2007
    • 70
    #16
    Re: mpc2504 gMAIL
    Hi,
    Yes, on both.
    We have configured it on a Kyocera and it works properly.
    As I said the only difference we can see is that the Kyocera has a function that can use STARTTLS instead of
    standard SSL & TLS.
    It is a confusing machine to say the least
      • 30250
      #17
      Re: mpc2504 gMAIL
      Just for test try different gmail account or your own.
      • mdtrinh
        • Aug 2010
        • 68
        #18
        Re: mpc2504 gMAIL
        Originally posted by ATSBMCO
        Still Having issue's here. Still not working properly.
        What we have found out after programming a Kyocera MFD, the Kyocera worked, is that the Kyocera offers SSL/TLS & STARTTLS.
        Selecting STARTTLS and port 587 and all is good.
        Now, I can't find STARTTLS on the RICOH. Appartently I should be using SSL, but it still fails with 'SSL Negotiation failed'.
        Anybody know of any other setting with the Ricoh that they could help me with?
        Cheers
        I think you have have to create self-signed device ssl certificate in order to make it work.
        Log-in as admin, device management -> configuration -> security -> device certificate.
        Create a self-sign device ssl certificate (I use default setting with 10 year range).
        Hope this help.
        Minh
          • 37510
          #19
          Re: mpc2504 gMAIL
          Hope this help.
          Minh
          SMTP over SSL requires a site certificate not a device certificate. The first models that supported SMTP over SSL required that you install a site certificate but later models came with one installed but I have encountered problems when the certificate expires. If you have a machine either with no site certificate or an expired certificate, see the attached. How do I setup SMTP over SSL on a Ricoh Family group device.pdf
          • ATSBMCO
            Technical
            • Oct 2007
            • 70
            #20
            Re: mpc2504 gMAIL
            Thanks for your reply.
            I've set the site certificate with the Equifax from IE like you suggested, and no still says Authentication failed.
            Checking the print out it says: SSL Negotiation failed. ERR:
            We put the same details into a Kyocera TA3051ci and it works like a dream.
            Garbage!
              • 37510
              #21
              Re: mpc2504 gMAIL
              Garbage!
              Have you tried all three options in the link I posted earlier? It is written by Google support specifically in response to Google Suite and Google Docs user complaints about being unable to scan to email. Here's the link again. Send email from a printer, scanner, or app - G Suite Administrator Help
              • mdtrinh
                • Aug 2010
                • 68
                #22
                Re: mpc2504 gMAIL
                Garbage!
                I had the same problem with your site certificate Equifax set up, expiration was good, but fail SSL negotiation.
                Finally, I got it work with set up device certificate, self-signed device ssl certificate as mention in early post.
                I also removed site certificate, and still work like a charm.
                Only remaining problem I have is airprint not working on my MPC3003, but working fine on MPC4503 with same setting.
                Both machines work fine with scan to email, using gmail account, SSL, port 465
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  #23
                  Best thing to do sp 5801 reset ncs and scanner options reboot machine setup from start let machine pick up all the info from the network
                  Setup a new Gmail account
                  Turn on allow less secure apps
                  smtp.gmail.com
                  email address
                  email address
                  password
                  Turn on ssl
                  Put the email in Administrator email on machine
                  If you get Authentification error check in the email inbox for security message
                  Regards Mark
                    • 37510
                    #24
                    Re: mpc2504 gMAIL
                    smtp.gmail.com
                    email address
                    email address
                    password
                    Turn on ssl
                    Just make sure that you reset only those items that need to be reset. Never do all or engine unless you have the birth certificate in your hand.
                    • copier tech
                      • 8164
                      #25
                      Re: mpc2504 gMAIL
                      I've had a few "buggy" 04's recently, mainly new models on install, icons missing, DF jams, screen lock ups etc each time putting the latest package resolved the issues.
                      • ATSBMCO
                        Technical
                        • Oct 2007
                        • 70
                        #26
                        Re: mpc2504 gMAIL
                        I've noticed when looking through scanner settings in the browser ( general/initial settings etc...)
                        at the top it says:
                        [Note] SSL communication is currently unavailable. The following items will be transmitted without being encrypted.
                        However, in the Security everthing is activated. SSL, TLS, and so on.
                        In the email settings I have SSL on and authentication is on too.
                          • 37510
                          #27
                          Re: mpc2504 gMAIL
                          at the top it says:
                          Do you have any install applications that use SSL? If you do, SSL might not be available for email.
                          • sandmanmac
                            • 3981
                            #28
                            Re: mpc2504 gMAIL
                            at the top it says:
                            I'd like to tell you that you were on to sonething here, but while I have no idea what exactly that message means, it's always there, and has never affected any of my setups, including (as I stated initially) my own MP301, which is currently configured with my Gmail account
                            • SargeNZ
                              • May 2012
                              • 263
                              #29
                              Re: mpc2504 gMAIL
                              The SSL warning message is to do with how data is transferred between your browser session and the machine on the network, in theory someone could packet sniff any folder passwords etc that you were submitting via the web browser since you are not using HTTPS, it is NOT related to SSL for email.
                              At this point, if I was OP, I would be clearing the scanner network memory in SP mode, as well as holding the # key before entering user tools / system settings to start from scratch there as well.
