SC 540-00 on a brand new MPS 2504ex
  • Roger67
    • Nov 2013
    • 84
    Hi Folks,
    i have a brand new MPC 2504ex who comes with a SC 540-00 but only in the high Quality mod,means the 4.Calibration Chart,or when using
    thick 2-3.
    When the maschine runs in normal mode/speed it works great.
    Any Ideas ?
    Cheers
    Roger
  • onion
    • Dec 2017
    • 2
    Re: SC 540-00 on a brand new MPS 2504ex
    Any fusing issue first check the power to the machine. Is it a steady 115-120? The thick mode is going to need a little more juice and could be kicking out the code. We have a few customers right now popping these codes whenever someone turns on their space heater.
    • Roger67
      • Nov 2013
      • 84
      Hello,
      the Power seems to be OK.
      We got 220 V hier in CH.
      Question: Ist there a Possability to adjust the Torque of the Fusing Motor in the SP Mode ?
      It Looks that the Motor losses its Power during the slow passage of the Paper.
      Until now,i changed: Fusing Unit , IOB Transport , IOB Imaging , PCB Image Proc Unit , BCU
      I also updated the Firmware.
      Now i am out of any Ideas ...................
      • copier tech
        • 8195
        If its a brand new machine log a ticket with Ricoh under warranty don't waste your time & money!
        • Roger67
          • Nov 2013
          • 84
          Good morning,
          after spending hours of hours trying to fix this Sc540-00 i can inform you,that the Drive Unit/Paper Exit Unit ( D2411357 ) or maybe one
          of the Motors on it was the Problem.
          Greetings
          Roger
          • Roger67
            • Nov 2013
            • 84
            Hi Folks,
            sadly i have to inform you that our Problem Maschine comes again with a SC 540-00 after installation of a
            SR 3180 Finisher.........................
            When i fixt the Maschine if done several Hundrets of Copy/Prints in the highest Solution without any Problem.
            Now with the Finisher,this f.....g Maschine makes me cracy.
            I think we put this f..k in the Press.
            Greetings
            Roger
