Mpc5501 scan to email error
  • mrfuser
    • 1626
    Transmission has failed. Insufficient memory in the destination hard disk. To check current status press (Scanned Files Status)
    Any thoughts?
    • 30516
    Re: Mpc5501 scan to email error
    Any thoughts?
    check if scanning in color also check scan memory should be off or set to maximum
    • mrfuser
      • 1626
      Scan memory? Sorry what do you mean ?
        • 30516
        check under scan settings or file transfer default size is 2200mb increase to 124000mb
          • 37606
          Since it says in the destination hard drive I would have the customer see if their inbox is full.
          • copier tech
            • 8205
            Reading & understanding what the message is telling you is the secret to many issues!
              • 30516
              Nothing to do with destination HHD error is from machine HHD being restricted do to large file size
              check scan settings default is 2200mb
              Send Settings
              • mikedci
                • Jul 2010
                • 227
                also check the scanner journal isn't full. we usually set it to do not print delete oldest...
                • SargeNZ
                  • May 2012
                  • 263
                  I've seen this exact error when the SMTP server is dropping the job for exceeding the file size quota. I think by default for IIS it's something like 20mb.
