Ricoh MPC305 - broken Guide Plate : Reverse Upper
  • dave w
    • Jun 2015
    • 230
    Can anybody advise if they have found a easy way of replacing Guide Plate : Reverse Upper without stripping the whole scanning unit of the machine first.
    It the reverse paper guide that sits about the fusing unit and breaks on the left hand side which causes the paper to jam on a duplex request.
    there must be an easy / hack way of taking it out with stripping the machine down.
    the machine I need to fix is in a dark room and at chest hight! .. no other place to move it to as its a nursery with children running about.
    Any advise welcome
    Ohh I do have a head torch.
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: Ricoh MPC305 - broken Guide Plate : Reverse Upper
    The exit unit?
    Does not look like there is a short cut.
    Your have to move the machine to a more convenient place to work on it.
    • copier tech
      • 8221
      Its not so bad once you changed a few. Still easier than repacing some units on this little box!
      I’ve got one to change this week as it happens!
      • dave w
        • Jun 2015
        • 230
        Thanks Cipher and Copier tech.
        Yes thought so. only one way to do it.
        Thanks all the same.
        Dave
        • Zaxxon
          • 608
          The scanner unit pops off rather easy.
          Please start you post with brand, model, problem.
          • Kimi
            • Feb 2018
            • 105
            about 30 min job, as previously said, one of the easier ones.
            • dave w
              • Jun 2015
              • 230
              Thanks everyone.
              Yes ive done it before, Once in a basement with bad lighting and the other was in a dark corner behind a busy/bumpy dentists reception desk.
              Seems to be my trial in life to fit parts in the dark! lol
              Part on back order so i have a rest period to eat as many carrots as possible before the visit.
              Dave
              • Zaxxon
                • 608
                Originally posted by dave w
                Thanks everyone.
                Dave
                I always tell the costumer to move the box to a repairman convenient location, OR NO REPAIR!!! Do not comprise your health, no one will ever thank you for it.
                • copier tech
                  • 8221
                  This is the one I did today, only took around 45 mins taking my time, only thing to watch out for is the fragile scanner ribbon cable.
                  • Cipher
                    • May 2006
                    • 1309
                    [ATTACH=CONFIG]39376[/ATTACH]
                    School library?
                    • copier tech
                      • 8221
                      Originally posted by Cipher
                      School library?
                      Correct! A North London college.
                      • dave w
                        • Jun 2015
                        • 230
                        All sorted - luckly it was a sunny day.
                        I tool a cab to place it on and did it out side. Not only a completed job but topped up my Vit D levels as well.
                        • copier tech
                          • 8221
                          [ATTACH=CONFIG]39387[/ATTACH]
                          You must have found the only day in months its not been raining!
                          • dave w
                            • Jun 2015
                            • 230
                            Ha ha yes i thought that. very lucky.
                            The only issue was making sure i didnt drop any screws as the gaps between the bricks on the driveway would of given me a challenge.
