Mpc5501 Locked up
  • mrfuser
    • 1611
    Mpc5501 Locked up
  • anothertech
    • 1759
    Re: Mpc5501 Locked up
    Try booting the machine with the hard drive disconnected.
    • Drummer
      • Feb 2013
      • 46
      I would try unplugging the HDD and see if it comes to a ready state.
      I have seen machines just say "please wait" forever and throw no codes etc. when the HDD was bad.
      • mrfuser
        • 1611
        Yes indeed it was a dead drive. Ordering a replacement
        • TonerMunkeh
          Professional Moron
          • 3865
          Just format it with a caddy, the drive itself should be fine.
          Hit it.
          • ?09317
            • Nov 2017
            • 8
            Please remove the fax control panel on the main control board, replace the main control board and then boot to enter the sp mode and then execute 5832 and then successfully install the fax interface panel to ok.
            • ?09317
              • Nov 2017
              • 8
              Please remove the fax control panel on the main control board, and then boot to enter the sp mode and then execute 5832 and then successfully install the fax interface panel to ok.
              • ?09317
                • Nov 2017
                • 8
                My English is not good enough, I hope you can understand what I mean to help you
                • ?09317
                  • Nov 2017
                  • 8
                  The above message said less than a program, I deal with this mpc series model wait wait this problem, first remove the fax board and boot into sp mode I will execute the 5846-050 and 5832 these two programs, mpc3500-mpc5501 series models I did not change Hard disk HD
