1075
  • copy.eva
    • Jun 2012
    • 33
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: 1075
    I'm going to go out on a limb here and say the motor is either bad, not receiving power, or bound up.
    What have you tried on the machine to make it work again?
    • fshead
      • 2376
      Re: 1075
      did you pull the dev unit and try to turn it by hand?
      an old unit like that the dev unit might be bound up.
      • copy.eva
        • Jun 2012
        • 33
        Re: 1075
        • copy.eva
          • Jun 2012
          • 33
          Re: 1075
          When the motor was running in Output check, the development unit was out of the machine 😊 P.S The same motor is working on another machine 😊
          • fshead
            • 2376
            Re: 1075
            you need to ck what the motor is turning ie the dev unit
            • fshead
              • 2376
              Re: 1075
              When the motor was running in Output check<<??are you saying tested in output check? and it did not turn?
              • copy.eva
                • Jun 2012
                • 33
                Re: 1075
                • fshead
                  • 2376
                  Re: 1075
                  I work on a lot of old stuff but have tossed all my 1075 parts out over 5 years ago..And
                  I saved tons of motors,brds,adfs etc and never changed a dev motor.
                  do you have the point to point on this machine/
                  are you even able to get anything if you figure it out? 16 yr since introduced in usa
                  • Introduction Date: 07/2002
                  Outside of broken wire or bad connections,I would just swap a complete controller if you are parting out from the
                  scrap pile..
                  • davel
                    • Oct 2011
                    • 1103
                    Re: 1075
                    Check drive section between motor and dev unit.
                      Re: 1075
                      why jump right to the boards? you should have pulled the dev unit out and checked it first!
                      in 30+ years of doing this 90% of the time it's the $3 part not an $800 board.
                      Time to hone your diagnosing skills ....
                      • copy.eva
                        • Jun 2012
                        • 33
                        Re: 1075
                        • fshead
                          • 2376
                          Re: 1075
                          >>i too thought locked up dev unit,but if you read my back and forth to this tech they latter
                          explained that they ran the output test without dev unit installed..
                          plus aint too many $3 parts from ricoh that i know of
                          • copy.eva
                            • Jun 2012
                            • 33
                            Re: 1075
                            [IMG]blob:http://www.copytechnet.com/31a71efa-6dcc-47fe-9491-6e05f7e30bd8[/IMG] Problem solved! I replaced this switch (little piece of shit &#128522 which is placed behind the main switch (On/Off). Anyway, thanks to everyone 😊 Greetings
                            • copy.eva
                              • Jun 2012
                              • 33
                              Re: 1075
