ricoh spc830dn and mpc3502/4502 fuser units
  • mavetherave311
    • Oct 2012
    • 11
    is it possible to put a ricoh mpc3502/4502 fuser unit into a ricoh SPC830DN
  • davel
    • Oct 2011
    • 1107
    Re: ricoh spc830dn and mpc3502/4502 fuser units
    Why would you, the printer version is much cheaper.
    • fshead
      • 2376
      I THink sometimes independant tech are limited what they have around..
      I myself gut the older ricoh color printers for parts on the copier side.
      • copier tech
        • 8174
        Yes you can, same with the ITB, you just need to swap over a jumper & a few covers, compare the two.
        • mavetherave311
          • Oct 2012
          • 11
          thanks for the help guys,its just that ive got plenty of mfd fusers available to me
          • blazebusiness
            SanDiegoCopierRepair.com
            • 1257
            I have heard rumors that the fuser lamps are different in the C3502 and C4502. You can use the C4502 and C5502 fusers in the SP C830dn. The C3502/C3002 fuser may have compatibility issues and not last long.
            MPC4502/5502 you can fit all kits from the SPC830, so PCDU, transfer, fuser/PTR
            MPC4502/5502, change the complete connector assembly, easiest way to do it is take all the external covers off, unplug the lamp wiring from both sides and 3 screws (1 x earth screw and 2 x plug screws) swap them over and put covers back on and your done.
            As for the MPC3002/3502, you do the same as above along with replacing the base plate of the fuser due to the fact when the fuser locks into the device, on the 3002/3502 it is located in a different spot and your done.
            MP5000/5001/5002 will fit the Maintenance Kit A and B from the SP8200
            MPC4500 you can fit any of the maintenance Kits from a SPC811dn, so PCDU, transer, fuser/PTR
            MPC5000/5501 you can fit the SPC820dn maintenance kits in, so PCDU and transfer units are no problem, the MPC5000 will take the SPC820 fuser but wont fit in the MPC5501
