mpc 4502
  • COPYMAC
    • Feb 2011
    • 13
    [Misc] mpc 4502
    hello, good afternoon in an mpc4502 when making copies in duplex with single pass adf, the second side comes out in black
  • jonhiker
    • 661
    Re: mpc 4502
    could be a problem with the CIS that scans the second side
    • copier tech
      • 8142
      Re: mpc 4502
      Had this exact same issue after cleaning the engine, it deleted the DF settings, if you have the birth certificate (inside front door) check all the feed settings for yoir single pass DF you will find some at zero when should be like 800.
      • mikadonovan
        • May 2008
        • 2931
        Re: mpc 4502
        I had that problem, too.
        http://www.copytechnet.com/forums/ri...tml?highlight=
        NEVER ASSUME ANYTHING
        • Tatteous
          • May 2017
          • 24
          Re: mpc 4502
          I had the same problem. It was the CIS. It was less money to buy a high meter used machine than it was to replace the CIS.
          • COPYMAC
            • Feb 2011
            • 13
            Re: mpc 4502
            Originally posted by mikadonovan
            if I probe with another cis but the problem continues.
            Thank you
            • COPYMAC
              • Feb 2011
              • 13
              Re: mpc 4502
              change the df and the boards but the problem continues.
              • mikadonovan
                • May 2008
                • 2931
                Re: mpc 4502
                This is from another thread with the same problem.
                "the smc sheet under the front door DID have the values!! and It worked!!! Thanks to all who responded
                The default value on my machine were
                4-712=3666
                4-713-3741
                4-714- 4082
                In case some else needs a starting point"
                Enter SP mode>system> and enter the values above. It may not be the exact numbers needed as they vary with each CIS, but it may get a second side image. If it does, and you do not have the birth certificate of the machine, you can change these values a little at a time until you achieve an acceptable image.
                If you have the birth certificate of the machine with these values on it, use them but reinstall the ORIGINAL DF beforehand. These values are stored in machine memory, not in the document feeder.
                It DOES NOT MATTER if you change the document feeder, the machine STILL does not have values entered for these SP's. I said this because you have not indicated that you have even checked to see if these values have been entered.
                Ok, I'm done.
                • COPYMAC
                  • Feb 2011
                  • 13
                  Re: mpc 4502
                  4-712=3666
                  4-713-3741
                  4-714- 4082
                  Ok, I'm done.
                  thanks I did this and it worked, these codes do not appear in the manual, only in the factory settings sheet.
                  greetings from Chile
                  • copier tech
                    • 8142
                    Re: mpc 4502
                    You're welcome, Like I said had this exact same fault!
