supplies order has failed - Black
  • andy227
    • Jan 2013
    • 219
    Went to a mpc5502 for a service call but also noticed the "supplies order has failed - Black, - yellow" message flashing. We don't use any remote ordering set-up so i was looking into how to get rid of the message permanently.
    In the manual there is 5507-003 toner supply alarm on/off, 5515-010 supply automatic ordering, 5816-001 remote service on/off. Which of these would I have to switch off to get rid of the message ?
    Also, while noseing around looking for a way to switch off the message, I went into 5045 accounting counter, which was set to prints (1), and I inadvertingly set to (0) dev count, by accident and realised it after I left and saw the counter sheet. I heard that you can only change it once, can I not change it back ? I am badly goosed here ? developer count is not an option here, have to get it back. Advise welcomed .
  • jonhiker
    • 661
    Re: supplies order has failed - Black
    5515-10 will turn off that message
    • davel
      • Oct 2011
      • 1106
      Have you tried factory mode to reset 5-045.
      • Zeldaman
        • Mar 2011
        • 946
        Hi there!
        I think since the MPC 5000 you can switch dev/page count as often as you want.
        Greetings...
        • DRichard
          • May 2008
          • 482
          Originally posted by Zeldaman
          Hi there!
          Greetings...
          I hadn't heard that...but I'm not sure I want to risk testing it. If anyone can confirm this, please post it.
          "Enjoy every sandwich."
          -- Warren Zevon
          • francisco
            • Nov 2009
            • 168
            5816-209 reset remote settings
            • andy227
              • Jan 2013
              • 219
              Thanks for both suggestions, I guess I'll try both and see what happens.
              I don't think so, the manual of all those machines definately says can only be changed once.......
              Have you tried factory mode to reset 5-045 ?
              No, but I will try it, as soon as I find how to get into factory mode, as I have never needed to get into it before so I am one of those sad cases that didn't know it until now. And I won't ask on a public forum....
                make sure you have the birth certificate before you do the reset
                • andy227
                  • Jan 2013
                  • 219
                  why ? We are just doing a counter method change, not a memory clear.
                    • 37508
                    If you have to use factory mode and do a factory, the only way I know of to clear the counter method change, it might also change other things.
                    • andy227
                      • Jan 2013
                      • 219
                      anyone actually done this so we know for sure ?
                      • anothertech
                        • 1771
                        Don't do any big memory clears, you'll just make things worse. Do 5870-003 and 5870-001 then 5816-209 then reboot.
                        • Tatteous
                          • May 2017
                          • 24
                          5515 010 set to 0
                          5515 011 set to 0 (per Ricoh)
                          Go into the Web Image monitor. Auto email Notification and delete and fields that have values.
                          5816 209 is only to clear an @ remote installed numerical value. It does not have anything to do with auto supply ordering.
                          Factory mode
                          Clear modes (Reset) 143. press clear or stop if there is no clear button. press and hold stop until screen changes.
                          • Imprestik
                            • Aug 2012
                            • 297
                            As stated above,
                            Remove and reissue the certificate by using
                            SP5-870-003
                            then
                            SP5-870-001
                            Reboot and it will get rid of the error
                            Do a firmware update too if it's out
                              • 8164
                              Yes you can simply set SP5045 accounting counter back to 1 don't do a memory clear for something so simple!
