Toner Empty- MP C2503
  • certifiedxeroxtech
    • Nov 2009
    • 27
    I'm having an issue of toner depletion inside the Development unit of MP C2503. I began to force toner supply and the spiral gear inside the sub hopper gets twisted and been cut on its shaft due to the toner stocked at opening of the development unit. Toner sensor inside was never detecting physically toner empty. Any ideas? My next solution is updating engine firmware.
    "prepare your contingency plan as always"
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Toner Empty- MP C2503
    Replace the sub hopper and dev unit on the affected colour.
    Hit it.
    • davel
      • Oct 2011
      • 1107
      Why would you think firmware would fix it?
        • Nov 2009
        • 27
        thanks for the responses. DV and PCU replaced but still toner get stocked on the opening.
        No gears defective. DV clutch ok.
        Why I had to suspect the firmware? because I am guessing, sensor on dv is not detecting toner. Could you suggest another stuffs?
        • TonerMunkeh
          Professional Moron
          • 3865
          The sub hopper needs to be replaced.
          Hit it.
          • Zeldaman
            • Mar 2011
            • 946
            • anothertech
              • 1771
              I agree with this, I have had to replace the sub hopper for this problem, no fun to replace, thing are kinda tight in the back of the machine. Bring a good flashlight and small hands.
              • copier tech
                • 8182
                  • Nov 2009
                  • 27
                  dears, I've replace two sub-hoppers. It went snapped all of those. I repaired the 2nd hopper using a soldering iron and I decided to update firmware. Anyways. It was solved already. here's what I've done: Make sure to balance the toner inside the sub-hopper and inside the DV unit. make sure also to check the clogged of the tunnel-like connector of sub-hopper and DV unit kinda hard to reach inside.(requires long Screwdriver) and try to pay attention on the on New unit detection values on SP 3701. change it from 0 to 1 (PCU and Development). Customer is happy now.
