301 high pitch squeek
  • dchirnitch
    • Oct 2014
    • 13
    Have a high pitch squeek only during paper feed, usually the Xf roller, but not this time, also tried feed roller /Sep and oiled every thing in sight.??
    Re: 301 high pitch squeek
    what brand / model are you talking about?
    • TonerMunkeh
      Professional Moron
      • 3865
      Reg roller bushings are the next cause, they respond well to a bit of light oil.
      Hit it.
      • Wild Bill
        • Jul 2005
        • 774
        Only things I have ever had squeak were the Transfer roller bushings and the PCU, i hope its not a clutch for your sake.
        Good luck
        Izzy
        • Stormhammer
          • 150
          If its the MP 301 then it's the transfer roller. A drop of oil in the plastic bushings on either side will cure it. If that doesn't fix the issue and it sounds like it's coming from deeper in the machine and you have toner dusting it's the PCU.
          • FrohnB
            • Jul 2017
            • 1919
            Agree with Wild Bill. Have only ever had xfer or PCU squeak. What's the PM counter at? Those 301 PCU's are crap and don't last, switch it over with the 1515 PCU and you'll get your proper yield.
            Also, not sure if these models have them, but in the older Savin 3515/816/920 there was a contact plate on the shaft of the feed clutch rear of machine, and PCU clutch shaft. sometimes those need cleaned and greased.
            Omertà
            • apump
              • Mar 2009
              • 160
              If you know its not the transfer roller its the front bushing on the registration roller. I have had that twice. it snaps in on the front side, not hard to take out. clean it up and your good. just did this about 2 weeks ago.
                • 37489
                If it only happens while the paper is actually feeding, it could be the paper tray separation pad.
                • anothertech
                  • 1769
                  Go into output mode and run some motors, that will help you narrow down the area the noise is coming from.
                  • Elmo
                    • Feb 2010
                    • 541
                    Ive had a couple of feed clutch cause this
                    bit of a strip down to replace but not too bad
                    I Used To Live To Fix Things Now i Fix Things To Live
