Ricoh MPC2011 SC672-11
  • Voltageza
    • Jun 2017
    • 71
    Hi Guys
    I have a MPC2011 that is coming up with SC672-11
    I have done the following:
    Remove HDD.
    Update Firmware
    Clean DIMMs
    Check wiring and harness.
    When opening the front door and connect power cord the machine will start up. The touch panel works but not the hard buttons. Machine is also able to print.
    Any ideas
  • copier tech
    • 8202
    Re: Ricoh MPC2011 SC672-11
    I had this exact same issue. SC672-11 is a communication fault between the ops panel & controller.
    I replaced the harness this resolved my issue.
    • Polarbear
      • Feb 2012
      • 1070
      Originally posted by Voltageza
      Hi Guys
      Remove HDD.
      Update Firmware
      Clean DIMMs
      Any ideas
      This code is a bit of a nightmare, as a faulty fax unit as well as buggy firmware can also cause this. especially the power saving firmware went through a dodgy patch where the machine would code coming out of sleep mode.
      Press the GREEN button!!
      • francisco
        • Nov 2009
        • 168
        Hi Guys
        Remove HDD.
        Update Firmware
        Clean DIMMs
        Any ideas
        check toner bottles, once i had a faulty toner chip.
        • slot
          • Jul 2008
          • 341
          i have had this on mpc3003 several times and there is paper stuck in the feed units crushed up by the tray or damaged feed unit on the ones I had they always powered up ok if the door was left open.
          • Amrss
            • 46
            Hi Guys
            Remove HDD.
            Update Firmware
            Clean DIMMs
            Any ideas
            Hello, I'm facing the same problem right now
            Did you manage to solve the problem eventually?
              • 37590
              This thread is over 3 years old. It was dead and buried and you dug it out of its grave.
              If you have a problem, start a new thread, grave robber.
              • Amrss
                • 46
                Sorry, didn't know it's against the rules
                I tried posting my problem but to no avail
                  You have 35 posts already.
                  • Amrss
                    • 46
                    Didn't get your point
                      • 37590
                      You have been here for a year and still do not know how to create a new thread?
                      Let me educate you
                      1. You open the forum that you wish to post in
                      2. A the top of the page you will see "+ Post New Thread"
                      3. Click on that
                      4. Select a prefix if you wish
                      5. Type the title for you post. Caution DO NOT HAVE THE LAST 5 LETTERS OF YOU TITLE SPELL THE WORD PRINT IN ANY FORM, that makes it difficult for other techs to reply
                      6. Type the body of you post. Be as detailed as you can, we hate having to ask for omitted information. You can use the paperclip icon to add attachments.
                      7. Click submit new thread
                      • Amrss
                        • 46
                        Let me educate you
                        3. Click on that
                        I meant that I posted my problem and didn't get a solution ... So I replied here because the problem matches mine exactly.
                        Thanks anyways
                        • luca72
                          • Oct 2017
                          • 1791
                          if you search here on the forum, you will find tons of information, sc 672, is the most popular code
                          "I'll be back"
                            • 37590
                            Thanks anyways
                            We like liars even less than we like grave robbers. You got replies. 3 from me, 3 from luca72, 1 from Codex and 1 from anothertech.
                              I guess he can't search for his own threads .
