SC204
  • laser801
    • May 2014
    • 151
    [Error Code] SC204
    Hey People... My partner is pulling his hair out with a MP8001 getting a SC204...Already replaced the Polygon Mirror Motor... Could it be IPU??? Is there a calibration on this new motor...any help would be appreciated! Thanks in advance!
  • mikadonovan
    • May 2008
    • 2931
    Re: SC204
    Never had to calibrate a poly mirror motor in the past, and the goose guide does list the IPU as a possible fault for this sc code.
    NEVER ASSUME ANYTHING
      • 37486
      Re: SC204
      Polygon mirror motor error 3 - check harness and connections
      Loose ground spring on rear of D062 2261 PCU: Lower Ass'y, re form spring or replace.
      • TonerMunkeh
        Professional Moron
        • 3865
        Re: SC204
        The door switches can also cause this code.
        Hit it.
        • aktasson
          • Feb 2017
          • 201
          Re: SC204
          [Symptom]
          SC204 (Polygon mirror motor error 3: XSCRDY signal error) is displayed.
          It sometimes occurs when the power is turned ON or when the Start key is pressed.
          [Cause]
          Wrong SC code is displayed due to the noise generated by faulty contact of the PCU ground spring.
          1. The side of the machine, in contact with the ground spring, is dirty.
          2. The weakened gound spring causes faulty contact with the machine.
          [Solution]
          1. Clean the part where the PCU grounding spring contacts the machine.
          2. Fix the PCU grounding spring to its original form.
          • Sha123
            Re: SC204
            Originally posted by aktasson
            [Symptom]
            [Cause]
            [Solution]
            Thanks for the suggestion.
            It works.
            I was wondering how could it shows SC 204-00 if i changed the Cleaning blade.
            I cleaned the machine surface and tension the Drum earth spring.
            It works.
            • BLADE
              former propeller tester
              • 478
              Re: SC204
              hmm.. maybe it could cause faint prints as well (as in corrupt ID sensor signal)
                • 37486
                Re: SC204
                It works.
                It works.
                Polygon mirror failures usually occur during POST.
                • Thomas040
                  • Jul 2023
                  • 1
                  Re: SC204
                  I understand the frustration your partner is experiencing with the MP8001 and the SC204 error. Troubleshooting technical issues can be challenging. While I specialize in providing assistance on a wide range of topics, including academic ones, such as Medical Surgical Nursing Dissertation Topics, it seems that the current query falls outside the scope of my expertise. However, I encourage you to seek support from technical forums, user communities, or experts in printer maintenance and repair. They may be better equipped to provide specific insights and guidance to resolve the issue at hand. Best of luck in finding a solution for your printer problem!
                    • 37486
                    Re: SC204
                    Take your worthless SPAM and shove it up your ass.
                    • luca72
                      • Oct 2017
                      • 1778
                      Re: SC204
                      Seem an AI-BOT.
                      "I'll be back"
