SPC 830 fuser 407099 fit to MPCxx02
  • copier tech
    • 8142
    This may have been asked before but has anyone tried this if so what is involved to convert?
    Thanks in advance.
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: SPC 830 fuser 407099 fit to MPCxx02
    yes, this was treatend, not so long ago.
    Use base plate and connector from mpcxx02 on a spc830
    • Imprestik
      • Aug 2012
      • 297
      Don't use them in the MPC3002 and MPC3502 it will give you errors and not last long
      Only use in the MPC4502 and MPC5502
      • fshead
        • 2376
        hmmm.
        why would it work better in the faster series?
        would almost seem the 30 and 35 cpm machines would
        be a better fit..
        I have yet to get any c830 for parting out so i cant say
        • copier tech
          • 8142
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            It works for a few weeks but it will throw an SC542-002 code eventually.
            You can fit a new fuse to the unit but that will only work for a few weeks and pop up the code again and the only work around is to fit a genuine fuser AFTER using the SC5810-002 to pop the fuse...again.
            • Mark Bbb
              • Jun 2012
              • 1662
              I have fitted a spc830 F.U. in a mpc3002 4 months ago and have not heard client complaining.
              • copier tech
                • 8142
                Maybe the error only happens for the US 110v market?
                • fshead
                  • 2376
                  I dont get how it would work on the 45/55 cpm and not the slower 30/35s?
                  • eccelobo
                    • 113
                    Same here in Argentina. 220V
                    • Oze
                      Ricoh Fanboy
                      • Jul 2008
                      • 1663
                      To clarify...
                      We've had a lot of the 3002/3502 throw a code.
                      Most do...but some don't...as you guys have seen.
                      240v here in Australia but we buy the 220v part numbers as the parts guides only ever show 110v or 220v.
