'03 fuser noise
  • mikadonovan
    • May 2008
    • 2931
    '03 fuser noise
    Hi, All. I have a couple of new(used) machines, a c4503 and a c5503 that are exhibiting fuser crinkling noises with only 30k on the fuser. I did not find a bulletin on the issue. I have had to relube bearings on previous models to get good life out of the fusers, but those were close to the end of their life cycle. These fusers are rated at 400k, so issues at 30k just seem wrong. Has anyone else run into this?
    NEVER ASSUME ANYTHING
  • zed255
    How'd ya manage that?
    • 1024
    Re: '03 fuser noise
    Can happen at any time. Usually following someone poking at the fuser to free a jam.
    A crinkling sound is the kiss of death; seen these rip the sleeves right in two and bend the frame of the belt unit.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Re: '03 fuser noise
      Yep check the sleeve!!!!!!!!!!!!!
      Mystic Crystal Revelations
      • copier tech
        • 8236
          • 37652
          Re: '03 fuser noise
          Could be a new customer to his service territory or an existing customer just bought a used machine.
          • Gary Bowen
            Bowdog
            • Mar 2008
            • 250
            Re: '03 fuser noise
            Constantly. Even with complete fuser rebuilds (Fusing Sleeve, Pressure Roller, Bearings) beginning to see this after about 25K (FYI - When you take the fuser apart there is no damage to the Fusing Sleeve surface). There were some earlier Fusing Sleeves (MP C2051?) that we were to actually grease the inside of the sleeve where it ran on the sleeve cap.
            • Lagonda
              • Aug 2008
              • 1649
              Re: '03 fuser noise
              May be low copy count but how old are the fusers? The inner sleeve lube can dry out just sitting there not moving.
              • Mark Bbb
                • Jun 2012
                • 1662
                Re: '03 fuser noise
                We have experienced that when client is using - even only one - thick paper, you have this issue!
                Like someone said here, could be "new" machiens with very old fusers!
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  Re: '03 fuser noise
                  is using thick paper WITHOUT INDICATING IT !!!
                  • mikadonovan
                    • May 2008
                    • 2931
                    Re: '03 fuser noise
                    Or, it could be I work for an indy and we get low mileage off lease machines from a very large copier exchange. I do get to look at the SMC's of the equipment before we buy to weed out the iffy ones. It keeps us competitive as far as cost goes.
                    • mikadonovan
                      • May 2008
                      • 2931
                      Re: '03 fuser noise
                      God knows how long the equipment we get sits in a warehouse before we get it. I have read some posts about techs lubing the inside of the sleeve. What kind of grease do you use?
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        Re: '03 fuser noise
                        I wonder about that too, i dont believe someone has ever done that succesfully...
                        I have tried it, but failled (hard)!
                        • ShonRipz
                          • May 2017
                          • 33
                          Re: '03 fuser noise
                          I may be wrong, but I do believe there is a tsb currently for the 03 series for a clicking sound due to the fuser drive gears. There are updated gears that reduce adrasion. If that is not the cause then I would clean the stripper plate and possibly replace the fuser sleeve
                          • mikadonovan
                            • May 2008
                            • 2931
                            Re: '03 fuser noise
                            I remember there was a bulletin about a part number change on the fuser drive gears. I will check that out before resleeving a fuser. Thank you, that may be the fix.
                            • Lagonda
                              • Aug 2008
                              • 1649
                              Re: '03 fuser noise
                              i would be worried that someone got to the copier before you took possession of it and swapped their high mileage fuser for a younger one.
                              As for stripping and re-lubing the inside of the sleeve, forget it it's not worth the effort. The things are jig built and if you pull it to pieces it collapses into a pile fiddly parts and you end up damaging the sleeve trying to get it back together.
