Ricoh MP C300 Scanner driver on Windows 10
  • copier tech
    • 8237
    #16
    Re: Ricoh MP C300 Scanner driver on Windows 10
    You can simply create a gmail account then use this to set up scan to email or even easier scan to a USB pen then transfer to your PC etc.
    SMB scan to folder will work after after you update the firmware give me a shout if you need it.
    All these methods can send a file as a .pdf.
      • 37652
      #17
      Not if SMB and FTP are blocked by firewall or Microsoft security update. Customer IT, for security reasons, may not want to make the registry changes needed to make push to folder scan work. TWAIN and WIA are pull scans the same as what stand alone scanners use.
